BACKBEAT FIT - WIRELESS EARBUDS
Enjoy big sound in a small package with the ultra-light and portable BackBeat FIT 300 series of wireless sport earbuds. A sweatproof coating protects the earbuds during workouts, while unique patent-pending, secure-fit eartips make them comfortable for all-day wearing.
Move freely
You’re always in motion, and need your music to keep up. Portable and ultra-lightweight, these discreet wireless earbuds stay put during active use and take you comfortably from one place to the next.
Break a sweat
Don’t let moisture hold you back. With IPX5-rated water-resistance, sweatproof design and military-grade nano-coating, these earbuds were built to take on sweat, rain and spills.
Listen comfortably
Enjoy big sound in a small package with unique patent-pending, secure-fit eartips. Its stable, discreet form factor sits flush in your ear and stays put during active use.
Going for an evening run?
The reflective sport-weave cable provides visibility at night, while the secure 2-in-1 cable clip stays in place during active use. Clip it to your shirt, or use it as a cinch.
FEATURES
ULTRA-LIGHT AND PORTABLE - Comfortable all-day wearing with portable, ultra-lightweight design
SWEAT AND MOISTURE PROTECTION - Sweatproof coating by P2i and IPX5-rated water-resistant protection
SECURE FIT EARTIP DESIGN - The patent-pending, occlusive eartip design blocks out noise and stays secure during active use
6 HOURS OF POWER - Up to six hours of wireless listening on a single charge
As unstoppable as you are
When it comes to your workout, nothing gets in your way. Stay focused and distraction-free with wireless sport headphones that stay comfortably in place. BackBeat FIT provides superior stability with a behind-the-ear design and comfortable eartip. The only reminder that you're wearing them is the rich sound of your favourite playlist or podcast pushing you to your next personal best. -
Engineered for sport
Ready to go the extra mile or ten? Flexible and durable, BackBeat FIT pushes you further, withstanding the rain or a rinse under the tap with a waterproof design that meets the IP57 rating and an additional sweatproof nano coating. And whether you wear them running roadside or on the trail, the open eartip design lets you hear the sounds around you. -
You never quit, neither should your headphones
With up to eight hours of listening from a single charge, BackBeat FIT helps you power through a full week of workouts. Subtle voice alerts let you know how much listening time you have left, and the 15-minute quick-charge provides an hour of play to get you through the day's challenge.
- Poly - Plantronics Backbeat FIT 305 - earphones with mic
- Product Type
- Earphones - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Style
- Sports
- Lime green
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 106 dB
- Impedance
- 16 Ohm
- Microphone
- On-cable
- Controls
- Answer/end, play/pause, next/previous track
- Product Type
- Style
- Sports
- 14 g
- Lime green
- Recommended Use
- Protection
- Sweat-resistant
- Max Operating Distance
- 10 m
Audio Output
- In-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Total Harmonic Distortion (THD)
- <3%
- Sensitivity
- 106 dB
- Impedance
- 16 Ohm
- Diaphragm
- 6 mm
Microphone
- On-cable
Remote Control
- Controls
- Included Accessories
- Carrying pouch, 3 pairs of ear tips (small, medium, large)
- Cable Details
- Micro-USB charge cable
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 6 hour(s)
- Standby Time
- 240 hours
- Recharge Time
- 2 hour(s)
