The APP-5 transforms your Polycom Unified IP phone experience through remote answer/end and ring alert. Seamlessly connect your Polycom unified IP phone with all Plantronics professional wireless headset systems, including the CS product family and the Plantronics Voyager 510S professional bluetooth headset system.
Wireless Freedom
With a Plantronics wireless headset you can take your hands-free calls up to 300 feet from your desk. Search for files, send a fax, or consult a colleague all while taking or receiving a call. -
Ergonomics
Ergonomic studies have shown that using a Plantronics headset can reduce neck, shoulder and upper back muscle tension by as much as 41%. -
Productivity
Real-world studies have shown that using a Plantronics headset can increase worker productivity by up to 23%. -
Reliability
Today, the headsets are the first choice for mission critical applications like 911 dispatch centers, the FAA, and the U.S. armed forces.
- Poly APP-5 Polycom Headset Hookswitch Control - electronic hook switch adapter
- Product Type
- Electronic hook switch adapter
- Designed For
- CS 60, 70N; SupraPlus CS351N; Voyager 510S; SupraPlus Wireless CS351N, CS361N; SoundPoint IP 320, IP 330, IP 430, IP 501, IP 550, IP 560, IP 650, IP 670
- Product Type
- Designed For
- Poly CS 60, 70N , Poly SupraPlus CS351N , Poly Voyager 510S , Poly - Plantronics SupraPlus Wireless CS351N, CS361N , Poly - Polycom SoundPoint IP 320, IP 330, IP 430, IP 501, IP 550, IP 560, IP 650, IP 670
