Plantronics A10-11/A Amplified Cable
Quicklinx: 5D5RWS00 Mfr#: 33305-02
More than 50 in stock
£20.49 ex VAT
£24.58 inc VAT
Standard delivery Delivered within 3-5 working days
The A10 cable (a.k.a. A10-16) can be used with any H-series headset to connect directly into a phone's headset port. When the A10 cable is used, no other amplifier is required.
A10 Direct Connect Cable:
Easily connect any Plantronics H-series headset to a headset-ready phone via the headset port with A10.
Recommended for use in an environment with a mix of M22 amplifiers and direct connect solutions.*
Allows H tops to be used in amplified and direct connect systems – and reduces the risk that the wrong headset will be connected (Polaris on an M22 or H top on a U10P) which would result in degraded transmit.
Plantronics - in-line amplifier
In-line amplifier
Intended For
Phone
In-line amplifier
Intended For
Phone
Brand: Plantronics
Price Range Ex VAT: 0 - 50
