Plantronics 3.5mm QD Spare
Quicklinx: 6L2JWS00 Mfr#: 38267-01
Stock Status: Used Stock
£7.79 ex VAT
£9.34 inc VAT
Plantronics' mission is to enhance personal communication. Plantronics helps make people more productive, safe, and comfortable improving the clarity of communications. Plantronics is committed to ensuring that its products meet customer requirements and are committed to quality and customer satisfaction.
Poly headset cable
Cable
Headset cable
Cable Type
Headset cable
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 6L2J 041631
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £5.32
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Plantronics
Price Range Ex VAT: 0 - 50
