Philips V-line 273V5LHAB 27" 1920x1080 5ms VGA DVI-D HDMI LED Monitor
Quicklinx: 98Y6WS00 Mfr#: 273V5LHAB/00
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
37 in stock
£115.74 ex VAT
£138.88 inc VAT
Enjoy vivid LED pictures on this Philips display. Equipped with HDMI and stereo speakers, it's a great choice!
  • Mercury Free eco-friendly display
    Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • Easy display performance tuning with SmartControl Lite
    SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
  • HDMI-ready for Full HD entertainment
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • 16:9 Full HD display for the best viewing experience
    The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colours.
  • Built-in stereo speakers for multimedia
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • SmartContrast for rich black details
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
Philips V-line 273V5LHAB - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
42 kWh
Power Consumption (On mode)
29 W
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
64.6 cm x 24 cm x 47.1 cm
4.53 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, TCO Certified Edge
Display Type
Energy Class
Class A
42 kWh
29 W
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartContrast
64.6 cm x 24 cm x 47.1 cm - with stand
4.53 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , HDMI , DVI-D , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
19.65 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Included Software
Philips SmartControl Lite
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 64.6 cm - depth: 24 cm - height: 47.1 cm - weight: 4.53 kg , Without stand - width: 64.6 cm - depth: 5.7 cm - height: 39.8 cm - weight: 4 kg
ENERGY STAR Certified
20 - 80%
Philips V-line 273V5LHAB 27 Bundle deal on Philips V-line 273V5LHAB 27" 1920x1080 5ms VGA DVI-D HDMI LED Monitor
£214.91
Accessories (4)
98Y6 StarTech.com Monitor Mount - USB Passthrough In Stock £128.09
98Y6 StarTech.com Dual Monitor Mount - Stackable In Stock £146.29
98Y6 StarTech.com Cubicle Monitor Hanger In Stock £45.29
98Y6 StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Other bundles (5)
98Y6 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
98Y6 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.80
98Y6 C2G 5m Select High Speed HDMI with Ethernet In Stock £22.72
98Y6 C2G 10m Select High Speed HDMI with Ethernet In Stock £43.63
98Y6 C2G 15m Select High Speed HDMI with Ethernet In Stock £59.09
Diagonal Size: 27in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 100 - 150
