Brand
Philips V-line 243V7QJABF 24" 1920x1080 4ms VGA HDMI Full HD LED
Quicklinx: FLYKWS00 Mfr#: 243V7QJABF/39#EDU
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, VGA (HD-15), HDMI
More than 50 in stock
£124.99 ex VAT
£149.98 inc VAT
Express delivery Order within the next 13 hours for delivery tomorrow
IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS display gives you remarkably crisp images with vivid colors, making it ideal not only for photos, movies and web browsing, but also for professional applications which demand color accuracy. The Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setup like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display.
SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption. SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free technology applies a great solution to regulate brightness and reduce flicker for more comfortable viewing.
  • IPS technology
  • Ultra-narrow border
  • SmartContrast
  • SmartImage
  • Flicker-free technology
Philips V-line 243V7QJABF - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
18.3 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 200000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Voltage
Textured black
54 cm x 20.9 cm x 41.5 cm
3.5 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, ICES-003, SEMKO, DDC/CI, RoHS, ISO 9241-307, KCC, WEEE, cETLus, RCM, CU, DisplayPort 1.2
Display Type
Energy Class
Class E
31 kWh
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Multilingual
Sync on Green, sRGB colour management, Lead-free, Low Blue Light Mode, Flicker Free technology, Mercury free
Textured black
54 cm x 20.9 cm x 41.5 cm - with stand
3.5 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI (HDCP) , DisplayPort , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
18.3 W
18.3 kWh/1000h
Power Consumption (Typical)
13.82 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
With stand - width: 54 cm - depth: 20.9 cm - height: 41.5 cm - weight: 3.5 kg , Without stand - width: 54 cm - depth: 4.5 cm - height: 32.5 cm - weight: 3.08 kg
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
20 - 80%
Diagonal Size: 24in
Response Time: 4ms
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: Philips
Stock Status: In stock
