Your basket is empty
Philips Philips V-line 200V4LAB2 - LED monitor - 20" - 1600 x 900 -
Quicklinx: BWTBWS00 Mfr#: 200V4LAB2/00
Diagonal Size: 20in
Max Resolution: 1600 x 900
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15)
£62.88 ex VAT
£75.45 inc VAT
Express delivery Delivered on Tuesday
Enjoy vivid LED pictures with this attractive, glossy design display. Equipped with stereo speakers, it's a great choice!
LED-backlit LCD monitor - 20"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.2698 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Textured black, glossy black
47.9 cm x 20.1 cm x 36.9 cm
2.72 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, BSMI, cUL, SEMKO, DDC/CI, RoHS, Lead-Free, WEEE, CECP, TCO Displays, EAC, ISO9241-307
2 years warranty
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.2698 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartContrast, Mercury free
47.9 cm x 20.1 cm x 36.9 cm - with stand
2.72 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
19 Watt
Power Consumption Stand by
0.5 Watt
Apple MacOS X, Microsoft Windows XP / 7 / 8
Dimensions & Weight Details
With stand - width: 47.9 cm - depth: 20.1 cm - height: 36.9 cm - weight: 2.72 kg , Without stand - width: 47.9 cm - depth: 4.8 cm - height: 29.9 cm - weight: 2.39 kg
20 - 80%
BWTB C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.51
BWTB C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.26
BWTB C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £8.26
BWTB C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £8.13
BWTB C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £8.03
BWTB C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £40.41
BWTB C2G 2m HDMI to DVI-D Digital Video Cable In Stock £7.85
BWTB C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £54.46
Diagonal Size: 20in
Response Time: 5ms
Brand: Philips
Price Range Ex VAT: 50 - 100
