Philips Philips Dictation Speechmike III Pro Prem
Quicklinx: 9NCDWS00 Mfr#: LFH3500/00
The SpeechMike Premium takes dictation to a new level. May it be the free-floating studio quality Precision Microphone, a microphone grille with optimized structure, built-in noise-reduction pop filter, antimicrobial surface or the world's first motion sensor in a stationary digital dictation device - the SpeechMike Premium sets the good standard.
  • Free floating, decoupled microphone for precise recording
    The microphone in the SpeechMike Premium is decoupled from its housing for the most incredible crystal clear recording performance ever to be delivered by a desktop dictation device. The completely redesigned microphone suspension guarantees that almost no background, touch, click, air or structure-borne noise is recorded. This technique is derived from studio microphones to make sure there are no sound distortions whatsoever - and to guarantee outstanding speech recognition results.
  • Microphone grille with optimized structure for crystal clear sound
    A well-engineered microphone grille is able to make a high-end microphone as in the SpeechMike Premium stand out even more. The hexagonal holes used for the metal grille feature three times more open surface than its predecessor, engineered to provide crystal clear recordings.
  • Integrated pop filter for perfect quality
    The microphone area of the SpeechMike Premium is made of many different layers to make it sound as clear and original as possible. One of those is a fleece inserted above and below the microphone capsule. The fleece filters out sound distortions such as pop and hiss noise, guaranteeing perfect results even if dictating closely into the microphone.
  • Large speaker area for premium playback
    Compared to its predecessor, the SpeechMike Premium is equipped with a double sized-speaker area that enables it to play back recordings in clear and crisp quality.
  • Optimized control panel for comfortable working
    Philips is the creator of the ergonomic zones design. SpeechMike Premium has been tested and proven by users to have the most comfortable fit in the human hand. The dictation zone is optimized to keep thumb movement to a minimum. The buttons needed for the actual dictation functions are placed centrally, in the area most convenient for the thumb, guaranteeing perfect ergonomics and non-fatiguing usage for the user. Less frequently needed function buttons are clearly arranged above and below. All buttons used are formed to give as much tactile feedback as possible.
  • Ergonomically shaped for perfect fit in the hand
    As the rear of a dictation microphone is as important as the front, Philips put an emphasis on shaping it in a way so that it perfectly fits the human hand and reduces unintentional use of buttons. The trigger and the "command" button on the rear housing are engineered to be exactly where they need to be. There has never been a desktop dictation device that is as ergonomic as the SpeechMike Premium.
  • Integrated motion sensor mutes microphone when not in use
    Being on the cutting edge of technology, the Philips SpeechMike Premium comes with an integrated motion sensor, making it the first stationary dictation device that can be controlled by the movement of your hand. It detects when it's put on the table, mutes the microphone, and once it is being picked up again it unmutes the microphone. There are plenty of situations this feature can be greatly beneficial; just think of an incoming phone call or someone stepping in your office. In addition to that, custom events can be programmed, to pause and to continue the recording.
  • Freely configurable function keys for a personalized workflow
    The Philips SpeechMike Premium is the most advanced dictation microphone to date - and to give the user even more room to personalize their devices, Philips has added an instruction key at the top of the control panel - of course fully and freely user configurable, especially useful for programming speech recognition commands.
  • Polished surface for reducing unwanted touch noises
    The housing of the new SpeechMike Premium is made of high-class polymers. The cabinet is endued with a polished surface and the material includes a pearl metal additive providing a high quality metallic effect and making it non-sensitive to touch noises and fingerprints.
  • Antimicrobial housing and buttons for hygienic working
    The SpeechMike Premium's housing and buttons are made of antimicrobial synthetics, guarding it against all kinds of germs. Antimicrobial materials work against a wide range of different microorganisms such as bacteria, viruses, fungi, or algae.
  • Laser-scanned, self-cleaning trackball for extra smooth operation
    The SpeechMike Premium includes a built-in high-precision stainless steel trackball. Self lubricated and abrasive resistant Teflon bearings guarantee a smooth operation over the entire lifetime. In combination with a laser scanner and self-cleaning features, the trackball is as precise and durable as never before. On top of that, the trackball can even be taken out of the device for cleaning, if this should ever be required.
Philips SpeechMike Premium USB LFH3500 - speaker microphone
Speaker microphone
Recommended Use
Voice recorder
Dark pearl grey
Headphones Technology
Dynamic
Audio Specifications
Frequency Response 300 - 7500 Hz
Max Input Power
200 mW
Microphone
External
Microphone Technology
Electret condenser
Speaker microphone
4.5 cm
3.2 cm
17.5 cm
200 g
Dark pearl grey
Recommended Use
Voice recorder
Audio Output
Dynamic
Frequency Response
300 - 7500 Hz
Max Input Power
200 mW
Diaphragm
30 mm
Microphone
Electret condenser
Wired
Sensitivity
-37 dBV/Pascal
Frequency Response
200 - 12000 Hz
Signal-To-Noise Ratio
70 dBA
Audio Input Details
Uni-directional - 200 - 12000 Hz
Connector Type
USB 2.0 (4 PIN USB Type A)
Cable Details
USB cable
RoHS, Lead-Free
