Maximise desk space and secure PC clients to your Philips monitor SmartErgoBase with the client mounting stand. This simple versatile solution allows you to create an All-in-One-like setup for max productivity.
Simple All-in-One solution
This simple client mounting bracket allows for a simple low-cost solution to create a clutter-free all-in-one desktop computing form factor that makes efficient use of space-constrained environments. -
Easy to set up and use
The client mounting bracket fits right on to Philips's award-winning commercial monitor SmartErgoBase for easy PC and Thin Client mounting. -
Universal 100 mm VESA mounting pattern
Industry-standard VESA mounting holes guarantee mounting compatibility with most small form factor PCs and Thin Clients. -
Full ergonomic adjustability
The client mounting bracket's clever design allows for full ergonomic adjustments (height, swivel, tilt) on the Philips SmartErgoBase
- Philips BS7B2224B - thin client to monitor mounting bracket
- Product Type
- Thin client to monitor mounting bracket
- Black texture
- 12 cm x 3.1 cm x 14 cm
- 210 g
- Designed For
- S-line 223S7EHMB, 223S7EJMB, 223S7EYMB, 243S7EHMB, 243S7EJMB, 243S7EYMB
- Product Type
- 12 cm - 3.1 cm - 14 cm
- 210 g
- Shipping Dimensions (WxDxH) / Weight
- 15.6 cm x 13.1 cm x 6 cm / 280 g
- Black texture
- 0 °C
- 40 °C
- 10 - 80%
- Designed For
- Philips S-line 223S7EHMB, 223S7EJMB, 223S7EYMB, 243S7EHMB, 243S7EJMB, 243S7EYMB
