Philips Momentum 436M6VBPAB 43" 2840x2160 4ms HDMI DisplayPort USB-C LED Monitor
Quicklinx: FF9LWS00 Mfr#: 436M6VBPAB/00
Diagonal Size: 43in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort, USB-C
£449.00 ex VAT
£538.80 inc VAT
Experience a new level of entertainment immersion with the new Momentum 4K HDR display with Ambiglow lighting. An expansive 4K UHD display with DisplayHDR 1000 delivers ultra-crisp and vibrant image quality that will get you in the moment.
  • MultiView technology
    With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
  • UltraClear 4K UHD Resolution
    These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
  • DTS Sound
    DTS Sound is an audio-processing solution designed to optimise the playback of music, movies, streaming and games on the PC regardless of form factors. DTS Sound enables an immersive virtual surround sound experience, complete with rich bass and dialogue enhancement and maximised volume levels free of any clipping or distortion.
  • Adaptive-Sync technology
    Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artefact-free performance at virtually any frame rate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
  • Low Input Lag
    Input lag is the amount of time that elapses between performing an action with connected devices and seeing the result on screen. Low input lag reduces the time delay between entering a command from your devices to monitor, greatly improving play on twitch-sensitive video games, particularly important for playing fast-paced, competitive games.
  • Ambiglow Technology
    Ambiglow adds a new dimension to your viewing experience. The innovative Ambiglow technology enlarges the screen by creating an immersive halo of light. Its fast processor analyses the incoming image content and continuously adapts the colour and brightness of the emitted light to match the image. User-friendly options allow you to adjust the ambiance to your liking. Especially suited for watching movies, sports or playing games, Philips Ambiglow offers you a unique and immersive viewing experience.
  • DisplayHDR 1000
    VESA-certified DisplayHDR 1000 delivers a dramatically different visual experience. Unlike other'HDR-compatible' screens, true DisplayHDR 1000 produces astonishing brightness, contrast and colours. With the help of local dimming and super-high peak brightness of up to 1000 nits, images come to life with advanced highlights featuring deeper, more nuanced blacks. It renders a fuller palette of rich new colours, delivering a visual experience that engages your senses.
  • Quantum Dot Technology
    Quantum Dot Technology is an innovative semiconductor nanocrystal technology that precisely emits light to produce bluer blues, greener greens and redder reds. LCD monitors with Quantum Dot colour produce a more dynamic range of colours and show the true natural palette of colours in the picture. The result- vibrant, dynamic, see-it-to-believe-it colour.
Philips Momentum 436M6VBPAB - LED monitor - 4K - 43"
LED-backlit LCD monitor - 43"
Energy Class
Class C
Energy Consumption per Year
201 kWh
Power Consumption (On mode)
138 W
USB 3.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.245 mm
Brightness
1000 cd/m²
Contrast Ratio
4000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort, USB-C
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating, low haze
Black gloss textured
97.6 cm x 26.4 cm x 66.1 cm
14.71 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV, VCCI, BSMI, ICES-003, SASO, SEMKO, CB, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, KCC, WEEE, PSE Mark, ICES, J-MOSS, E-Standby, KC, KUCAS, EAC, cETLus, China RoHS, RCM, Ukraine
Display Type
Energy Class
Class C
201 kWh
138 W
Diagonal Size
43"
Viewable Size
42.51"
Built-in Devices
USB 3.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.245 mm
Pixel Per Inch
103.64
Brightness
1000 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
23 - 80 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese
Sync on Green, SmartImage, Frame Rate Control (FRC), Ambiglow, Low Blue Light Mode, Flicker Free technology, Mercury free, DTS Sound, Low Input Lag, Quantum Dot Technology, HDR (high dynamic range), 100% BT.709 colour gamut, Picture-in-Picture, Picture-by-Picture, 97.6% DCI-P3, 119% NTSC colour gamut, 145% sRGB colour gamut
97.6 cm x 26.4 cm x 66.1 cm - with stand
14.71 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
HDMI , DisplayPort , Mini DisplayPort , USB-C (DisplayPort 1.2 mode) , 2 x USB 3.0 downstream with Power Charging (Type A) , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+10
VESA Mounting Interface
200 x 200 mm
USB-C cable , USB to USB-C cable , HDMI cable , DisplayPort cable
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
162 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
With stand - width: 97.6 cm - depth: 26.4 cm - height: 66.1 cm - weight: 14.71 kg , Without stand - width: 97.6 cm - depth: 6.3 cm - height: 57.4 cm - weight: 13.96 kg
Shipping Width
109 cm
Shipping Depth
33.8 cm
Shipping Height
76.4 cm
Shipping Weight
20.72 kg
ENERGY STAR Certified
ENERGY STAR Version
7.0
20 - 80%
Diagonal Size: 43in
Response Time: 4ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: USB-C
Brand: Philips
Price Range Ex VAT: 300 - 500
