Wireless dimming
Enjoy smooth wireless dimming. The Philips Hue Wireless dimming kit combines a clever wireless dimmer and a Philips Hue White LED bulb. No installation needed. Just place the switch anywhere you like and use it as a remote control.
Comfort dimming
Just screw in the light bulb and turn on the light.
Place it anywhere
Place anywhere you need a light switch.
Use as a remote control
Wireless switch and remote control in one.
Control multiple lights with one switch
Control up to 10 lights at once with one switch.
Connect to your Philips Hue system
Connect to Philips Hue and discover the possibilities.
Installation-free dimming
With this installation-free kit, all you have to do is screw the Hue White LED bulb into your standard fixture and switch on the light. You can immediately control your light using the battery-powered Hue Dimmer switch. No need to call an installer.
Fast and simple installation
The battery-powered Hue Dimmer switch can be used as a standard wall switch. You can place it anywhere you want, using screws or the adhesive tape on the back plate of the switch. Installation is fast and simple, with no wires and no hassle.
Easy wireless control
The switch is magnetic and can be removed from the back plate. This means you can also use the Philips Hue Dimmer switch as a remote control for your light with an indoor range of up to 12 metres.
Once you're set up with your Philips Hue Wireless dimming kit, you can easily connect more Philips Hue lights to the dimmer switch. Link up to 10 Philips Hue lights to your dimmer switch and control them simultaneously.
The Wireless dimming kit belongs to the Philips Hue family, so it can be seamlessly integrated with other Philips Hue lights. If you install a Hue Bridge in your home, you can integrate your Philips Hue Wireless dimming kit into your system via the Philips Hue app, for even more experiences today and in the future.
Control your lights from your smartphone or tablet and set timers, notifications, alarms and more.
Installation free dimming
With this installation free kit, all you have to do is screw in the Hue White LED bulb in your standard fixture and switch on the light. You can immediately control your light using the battery-powered Hue Dimmer switch. No need to call an installer. -
The battery-powered Hue Dimmer switch can be used as a regular wall switch. You can place it anywhere you want, using screws or the adhesive tape on the back plate of the switch. It is a fast, simple installation with no wires and no hassle. -
The switch is magnetic and can be removed from the back plate. This allows you to also use the Philips Hue Dimmer switch as a remote control for your light with an indoor range of up to 12 meters. -
- Philips Hue Wireless Dimming Kit - wireless lighting set - LED light bulb - shape: A60 - E27 - 9.5 W - warm white light - 2700 K
- Product Type
- Wireless lighting set
- Light Source Type
- LED light bulb
- Supported Light Bulbs Qty
- 10
- Dimmer
- Shape
- A60
- Socket Type
- E27
- Wattage
- 9.5 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- Warm white light
- Colour Temperature
- 2700 K
- Luminous Power
- 806 lumens
- Beam Angle
- 180 degree(s)
- Platform
- Hue
- Communications Technology
- Zigbee
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- 10
- Dimmer
- Wireless, ZigBee Light Link, upgradable firmware
Light Source
- LED light bulb
- Shape
- A60
- Socket Type
- E27
- Wattage
- 9.5 W
- A+
- Warm white light
- 2700 K
- Colour Rendering Index
- 80
- Luminous Power
- 806 lumens
- Beam Angle
- 180 degree(s)
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Upgradable firmware, instant full light
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50 - 60 Hz
- 1 x CR2450
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Hue
- Zigbee
- Included Accessories
- Dimmer switch, battery
- Warranty
- 2 years
- Dimensions & Weight Details
- Dimmer switch - width: 35 mm x depth: 11 mm x height: 92 mm - 37 g , Light bulb height: 110 mm x diameter: 61 mm
- -10 °C
- 45 °C
