Brand
Philips Hue White LED Filament Light Bulb - A60 B22
Quicklinx: GG9HWS00 Mfr#: 929002241001
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT, Siri
Hurry, only 3 left in stock!
£16.66 ex VAT
£19.99 inc VAT
Bring vintage style to your standard light bulbs with this dimmable LED bulb featuring a coiled filament design. The smart bulb can be used with Bluetooth or paired with a Hue Bridge for ultimate control.
  • Vintage design meets modern capabilities
    Capture the popular look of Edison bulbs, featuring a distinct glowing inner coil and transparent globe, with smart filament bulbs. These smart retro-style LED bulbs combine the look and feel of simple vintage design with the power of Philips Hue smart lighting.
  • Control up to 10 lights with the Bluetooth app
    With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
  • Control lights with your voice
    Philips Hue works with Amazon Alexa and the Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp.
  • Set the right mood with soft white light
    Hue bulbs and light fixtures use a soft white light. Dimmable from bright daylight to low nightlights, these smart lights allow you to fill your home with just the right level of warm light when you need it.
Philips Hue White - LED filament light bulb - shape: A60 - B22 - 7 W - warm white light - 2100 K - transparent
Light Source Type
Transparent
Shape
A60
Socket Type
B22
Wattage
7 W
Wattage Equivalent
40 W
Energy Efficiency Class
G
Colour of Illumination
Warm white light
Colour Temperature
2100 K
Luminous Power
550 lumens
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa
Platform
Hue
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Light Source
Shape
A60
Socket Type
B22
Wattage
7 W
Wattage Equivalent
40 W
G
Energy Consumption per 1000h
7 kWh
Warm white light
Colour Temperature
2100 K
Colour Rendering Index
80
Luminous Power
550 lumens
Dimmable
Lifetime
15000 hours
Switch Cycles
50000
Upgradable firmware, instant full light, Android compatible, iOS compatible, twisted filament
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Bluetooth, Zigbee
Body Colour
Transparent
Warranty
2 years
Diameter
60 mm
Length
114 mm
46 g
8.8 cm x 7.5 cm x 17 cm / 80 g
-10 °C
45 °C
Type: Light bulb
Compatible With: IFTTT
Compatible With: Siri
Brand: Philips
Stock Status: In stock
