Brand
Philips Hue White LED Edison Filament Light Bulb - ST72 E27
Quicklinx: GG9KWS00 Mfr#: 929002459201
Type: Light bulb
Compatible With: IFTTT, Siri, Alexa, Google Assistant
23 in stock
£29.16 ex VAT
£34.99 inc VAT
With an elongated design and vintage feel, this Bluetooth-capable LED Edison bulb featuring a coiled filament can make a statement in any room. Use with Bluetooth controls or pair with a Hue Bridge to unlock more smart lighting features.
  • Vintage design meets modern capabilities
    Capture the popular look of Edison bulbs, featuring a distinct glowing inner coil and transparent globe, with smart filament bulbs. These smart retro-style LED bulbs combine the look and feel of simple vintage design with the power of Philips Hue smart lighting.
  • Control up to 10 lights with the Bluetooth app
    With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
  • Control lights with your voice
    Philips Hue works with Amazon Alexa and the Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp.
  • Set the right mood with soft white light
    Hue bulbs and light fixtures use a soft white light. Dimmable from bright daylight to low nightlights, these smart lights allow you to fill your home with just the right level of warm light when you need it.
Philips Hue White Edison - LED filament light bulb - shape: ST72 - E27 - 7 W - warm white light - 2100 K
Light Source Type
Shape
ST72
Socket Type
E27
Wattage
7 W
Wattage Equivalent
40 W
Energy Efficiency Class
G
Colour of Illumination
Warm white light
Colour Temperature
2100 K
Luminous Power
550 lumens
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa
Communications Technology
Bluetooth, Zigbee
Android compatible, iOS compatible
Light Source
Shape
ST72
Socket Type
E27
Wattage
7 W
Wattage Equivalent
40 W
G
Energy Consumption per 1000h
7 kWh
Warm white light
Colour Temperature
2100 K
Colour Rendering Index
80
Luminous Power
550 lumens
Dimmable
Lifetime
15000 hours
Switch Cycles
50000
Instant full light
Internet of Things (IoT)
Bluetooth, Zigbee
Warranty
2 years
171 mm
140 mm x 83 mm x 170 mm / 155 g
-10 °C
45 °C
Type: Light bulb
Compatible With: Siri
Compatible With: Alexa
Brand: Philips
Stock Status: In stock
