Philips Hue White GU10 Twin Pack
Quicklinx: DXV5WS00 Mfr#: 929001819502
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT, Nest
42 in stock
£23.33 ex VAT
£27.99 inc VAT
Add a Philips Hue white bulb to your system and enhance your home with warm white lighting that you can dim and control remotely. Automate your lights to make it seem like you're home when you're not or set timers.
  • Smart control, home and away
    With the Philips Hue iOS and Android apps, you can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left home, and switch them on if you are working late.
  • Timers for your convenience
    Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on.
  • Installation-free dimming
    Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation.
  • Control it your way
    Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms and more for the full Philips Hue experience.
Philips Hue White - LED light bulb
Light Bulb Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Socket Type
GU10
Wattage
5.5 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
300 lumens
Beam Angle
46 degree(s)
Dimmable
AC 220 - 240 V
Packaged Quantity
Light Bulb
LED light bulb
Socket Type
GU10
Wattage
5.5 W
A+
Power Factor
0.5
Warm white light
Colour Temperature
2700 K
Luminous Power
300 lumens
Beam Angle
46 degree(s)
Dimmable
Lifetime
15000 hours
Switch Cycles
50000
Upgradable firmware, instant full light, Android compatible, iOS compatible
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Internet of Things (IoT) Hub Compatibility
Philps Hue Bridge
Platform
Hue
Communications Type
Product-to-product
Communications Technology
Zigbee
Warranty
2 years
Diameter
50 mm
Length
57 mm
-20 °C
45 °C
Type: Light bulb
Compatible With: IFTTT
Compatible With: Nest
Brand: Philips
Price Range Ex VAT: 0 - 50
