Add a Philips Hue white bulb to your system and enhance your home with warm white lighting that you can dim and control remotely. Automate your lights to make it seem like you're home when you're not or set timers.
Smart control, home and away
With the Philips Hue iOS and Android apps, you can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left home, and switch them on if you are working late. -
Timers for your convenience
Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on. -
Installation-free dimming
Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation. -
Control it your way
Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms and more for the full Philips Hue experience.
- Philips Hue White - LED light bulb - GU10 - 5.5 W - warm white light - 2700 K
- Light Source Type
- LED light bulb
- Socket Type
- GU10
- Wattage
- 5.5 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- Warm white light
- Colour Temperature
- 2700 K
- Luminous Power
- 300 lumens
- Beam Angle
- 46 degree(s)
- Dimmable
- Platform
- Hue
- Communications Technology
- Zigbee
- Voltage Required
- AC 220 - 240 V
Light Source
- LED light bulb
- Socket Type
- GU10
- Wattage
- 5.5 W
- A+
- Power Factor
- 0.5
- Warm white light
- 2700 K
- Luminous Power
- 300 lumens
- Beam Angle
- 46 degree(s)
- Dimmable
- Lifetime
- 15000 hours
- Switch Cycles
- 50000
- Upgradable firmware, instant full light, Android compatible, iOS compatible
Power Requirements
- Voltage Required
- AC 220 - 240 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Communications Type
- Product-to-product
- Zigbee
- Warranty
- 2 years
- Diameter
- 50 mm
- Length
- 57 mm
- -20 °C
- 45 °C
