Philips Hue White B22 Twin Pack
Quicklinx: D5M8WS00 Mfr#: 929001137161
Marketing description is not available.
  • Smart control, home and away
    With the Philips Hue iOS and Android apps you can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late.
  • Timers for your convenience
    Philips Hue can make it seem like you're home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on.
  • Installation free dimming
    Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation.
  • Control it your way
    Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms, and more for the full Philips Hue experience.
  • Wirelessly controllable LED
    This LED bulb is wirelessly controllable if you connect it to the Philips Hue bridge for smart control or to the Philips Hue dimmer switch.
Philips Hue White Dual Pack - LED light bulb - shape: A60 - B22 - 9 W - warm white light - 2700 K (pack of 2)
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Shape
A60
Socket Type
B22
Wattage
9 W
Wattage Equivalent
60 W
Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
806 lumens
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Apple HomeKit, Hue
AC 220 - 240 V
Packaged Quantity
Light Source
LED light bulb
Shape
A60
Socket Type
B22
Wattage
9 W
Wattage Equivalent
60 W
A+
Power Factor
0.5
Warm white light
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
806 lumens
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Upgradable firmware, instant full light, Android compatible, iOS compatible, voice control, controlled via Wi-Fi, remote controlled, light scheduling
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit, Hue
Voice Controlled
Indirect
Package
Hanging box
Warranty
2 years
Diameter
62 mm
Length
110 mm
72 g
-10 °C
45 °C
