Philips Hue White and Colour Ambiance GU10 Starter Kit 3 Bulbs
Quicklinx: D6D6WS00 Mfr#: 929000261761
Type: Wireless lighting set
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
Hurry, only 2 left in stock!
£141.66 ex VAT
£169.99 inc VAT
Live in the future with this Philips smart lighting starter kit. By connecting to the included Bridge hub, you’ll be able to adjust your lights from your phone or tablet. The three included GU10 spotlight bulbs produce both white and coloured lighting to match any mood, and have a lifetime of 25,000 hours so they won’t need changing for quite some time. Set up a schedule to have them come on at designated moments, or if you’ve got the Apple HomeKit or Amazon Echo smart speaker, you can turn on the lights with a simple voice command.
Please note, you’ll need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
  • Smart light starter kit – control the lighting remotely
  • White and coloured bulb – choose from 16 million shades
  • Spotlight fitting with 25,000 hour lifespan
  • Schedule a timer to turn lights on automatically
  • Works with Apple HomeKit and Amazon Alexa
  • Be creative with millions of colors
    Play with light and choose from millions of colors to instantly change the look and atmosphere of your room.
  • Sync lights with music and films
    Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm.
  • Light up your gaming
    Lift your gaming experience to another level. Discover the amazing things you can do with Philips Hue.
  • Wake up and go to sleep naturally
    Philips Hue will help get you out of bed the way you like it, helping you to start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise and helps you to wake up naturally, instead of being woken up by the loud sound of an alarm clock.
  • Installation-free dimming
    Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation.
Philips Hue White and color ambiance Starter kit - wireless lighting set - LED light bulb with reflector x 3
Light Bulb Type
3 x LED light bulb with reflector
Supported Light Bulbs Qty
50
Total Wattage
19.5 W
Dimmer
Socket Type
GU10
Wattage
6.5 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
250 lumens
50
Total Wattage
19.5 W
Dimmer
Android compatible, iOS compatible
Light Bulb
Socket Type
GU10
Wattage
6.5 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
250 lumens
Lifetime
25000 hours
Upgradable firmware, instant full light
Power adapter, wireless bridge, network cable, dimmer switch, battery
Warranty
2 years
Dimensions & Weight Details
Light bulb height: 70 mm x diameter: 50 mm , Wireless bridge height: 26 mm , Dimmer switch - width: 35 mm x depth: 11 mm x height: 92 mm
-10 °C
45 °C
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 100 - 150
