Brand
Philips Hue White and Colour Ambiance E27 Single Bulb
Quicklinx: FFS0WS00 Mfr#: 929002216801
Select:
  • E27
Light your home smarter with Philips Hue
Imagine being able to turn off all your lights with one click. Discover the magic of transforming an entire room from study to home cinema with one tap. Or maybe use your lights to make it seem like you are home when actually you’re not. And when you are home, choose the right light setting to help you concentrate better or relax after a tough day.
Philips Hue White and Color Ambiance - LED light bulb - shape: A60 - E27 - 9 W - 16 million colours
Light Source Type
LED light bulb
Shape
A60
Socket Type
E27
Wattage
9 W
Wattage Equivalent
60 W
Energy Efficiency Class
A+
Colour of Illumination
16 million colours
Dimmable
Intelligent Assistant
Siri, Cortana, Alexa ready, Google Assistant ready - indirect
Platform
Hue
Communications Technology
Bluetooth
AC 220 - 240 V
Light Source
LED light bulb
Shape
A60
Socket Type
E27
Wattage
9 W
Wattage Equivalent
60 W
A+
Energy Consumption per 1000h
9 kWh
16 million colours
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Upgradable firmware, instant full light, Android compatible, iOS compatible, voice control, app-controlled
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Communications Type
Product-to-product
Bluetooth
Voice Controlled
Indirect
Package
Box
Warranty
2 years
Diameter
60 mm
Length
110 mm
72 g
8.8 cm x 7.5 cm x 16.5 cm / 104 g
-10 °C
45 °C
