Philips Hue White and Colour Ambiance E27 Kit with 2x Bulbs, Bridge and Dimmer
Quicklinx: FFRTWS00 Mfr#: 929002216806
Type: Wireless lighting set
Compatible With: Alexa, Google Assistant
£99.17 ex VAT
£119.00 inc VAT
Light your home smarter with Philips Hue
Imagine being able to turn off all your lights with one click. Discover the magic of transforming an entire room from study to home cinema with one tap. Or maybe use your lights to make it seem like you are home when actually you’re not. And when you are home, choose the right light setting to help you concentrate better or relax after a tough day.
  • Be creative with colors
    Play with light and choose from 16 million colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Sync with music and films
    Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm. Download the third-party apps and discover the amazing things you can do with Philips Hue.
  • Light up your gaming
    Lift your gaming experience to the next level. Download the third party apps and discover the amazing things you can do with Philips Hue.
  • Wake up and go to sleep
    Philips Hue will help get you out of bed the way you like to, helping you start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise, and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
  • Create your ambiance
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of summer sun or the ice cool daylight of winter.
Philips Hue White and Color Ambiance Starter Kit - wireless lighting set - LED light bulb x 2
Light Source Type
2 x LED light bulb
Total Wattage
18 W
Dimmer
White
Socket Type
E27
Wattage
9 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
806 lumens
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Apple HomeKit, Hue
AC 220 - 240 V
Total Wattage
18 W
Dimmer
App-controlled
Light Source
2 x LED light bulb
Socket Type
E27
Wattage
9 W
A+
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
806 lumens
Voice control, remote controlled, app-controlled
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub
Included
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit, Hue
Intelligent Assistant Compatible
Voice Controlled
Indirect
Product Material
Plastic
Body Colour
White
Dimmer switch, Hue bridge
IP20
61 mm
61 mm
110 mm
27 cm x 7.5 cm x 21 cm / 800 g
Brand: Philips
Price Range Ex VAT: 50 - 100
