Philips Hue White and Colour Ambiance E14 Twin Pack
Quicklinx: D5MFWS00 Mfr#: 929001301302
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
£57.00 ex VAT
£68.40 inc VAT
Philips hue combines brilliant LED light with intuitive technology. It will surely change the way you use light. Forever. Experiment with shades of white, from invigorating blue/white to cozy yellow/white. Or play with all the colors in the spectrum. Hue can wake you up. Help protect your home. Relive your favorite memories. Improve your mood. Even keep you informed about the weather. Not just stunning, hue is smart too. And it's tailored for you.
  • Be creative with millions of colors
    Play with light and choose from millions of colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Sync lights with music and films
    Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm.
  • Wake up and go to sleep naturally
    Philips Hue will help get you out of bed the way you like to, helping you start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise, and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm light helps you to unwind, relax and prepare your body for a good night's sleep.
Philips Hue White and color ambiance - LED light bulb
Light Bulb Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Shape
B39
Socket Type
E14
Wattage
6.5 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
16 million colours
Colour Temperature
2200-6500 K
Dimmable
AC 220 - 240 V
Packaged Quantity
Light Bulb
LED light bulb
Shape
B39
Socket Type
E14
Wattage
6.5 W
A+
Energy Consumption per 1000h
6.5 kWh
16 million colours
Colour Temperature
2200-6500 K
Dimmable
Lifetime
25000 hours
Instant full light, Android compatible, iOS compatible, remote controlled
Power Requirements
AC 220 - 240 V
Warranty
2 years
Diameter
39 mm
Length
117 mm
Type: Light bulb
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 50 - 100
