Philips hue combines brilliant LED light with intuitive technology. It will surely change the way you use light. Forever. Experiment with shades of white, from invigorating blue/white to cozy yellow/white. Or play with all the colors in the spectrum. Hue can wake you up. Help protect your home. Relive your favorite memories. Improve your mood. Even keep you informed about the weather. Not just stunning, hue is smart too. And it's tailored for you.
Be creative with colors
Play with light and choose from 16 million colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger. -
Wake up and go to sleep
Philips Hue will help get you out of bed the way you like it, helping you start your day feeling refreshed. The light brightness increases gradually mimicking the effect of sunrise and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day, the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep. -
Create your ambiance
Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun, or the ice cool daylight of winter. -
Light for your daily routines
Light influences your mood and behavior. Philips Hue can help you to customize your daily routines into moments you can enjoy. Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Stay focused with finely tuned bright white light. Or put your feet up and relax with a soft glow of white light for the perfect end of the day.
- Philips Hue White and Color Ambiance - LED light bulb - shape: B39 - E14 - 6.5 W - 16 million colours - 2200-6500 K
- Light Source Type
- LED light bulb
- Shape
- B39
- Socket Type
- E14
- Wattage
- 6.5 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- Colour Temperature
- 2200-6500 K
- Dimmable
- Intelligent Assistant
- Indirect
- Platform
- Hue
- Communications Technology
- Zigbee
- Voltage Required
- AC 220 - 240 V
Light Source
- LED light bulb
- Shape
- B39
- Socket Type
- E14
- Wattage
- 6.5 W
- A+
- Energy Consumption per 1000h
- 6.5 kWh
- 2200-6500 K
- Dimmable
- Lifetime
- 25000 hours
- Upgradable firmware, instant full light
Power Requirements
- Voltage Required
- AC 220 - 240 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Communications Type
- Product-to-product
- Zigbee
- Voice Controlled
- Indirect
- Package
- Hanging box
- Warranty
- 2 years
- Diameter
- 39 mm
- Length
- 117 mm
