Philips Hue White and Colour Ambiance E14 Bulb
Quicklinx: D5MDWS00 Mfr#: 929001301301
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
£41.66 ex VAT
£49.99 inc VAT
Philips hue combines brilliant LED light with intuitive technology. It will surely change the way you use light. Forever. Experiment with shades of white, from invigorating blue/white to cozy yellow/white. Or play with all the colors in the spectrum. Hue can wake you up. Help protect your home. Relive your favorite memories. Improve your mood. Even keep you informed about the weather. Not just stunning, hue is smart too. And it's tailored for you.
  • Be creative with colors
    Play with light and choose from 16 million colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Wake up and go to sleep
    Philips Hue will help get you out of bed the way you like it, helping you start your day feeling refreshed. The light brightness increases gradually mimicking the effect of sunrise and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day, the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
  • Create your ambiance
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun, or the ice cool daylight of winter.
  • Light for your daily routines
    Light influences your mood and behavior. Philips Hue can help you to customize your daily routines into moments you can enjoy. Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Stay focused with finely tuned bright white light. Or put your feet up and relax with a soft glow of white light for the perfect end of the day.
Philips Hue White and color ambiance - LED light bulb
Light Bulb Type
LED light bulb
Shape
B39
Socket Type
E14
Wattage
6.5 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
16 million colours
Colour Temperature
2200-6500 K
Dimmable
AC 220 - 240 V
Light Bulb
LED light bulb
Shape
B39
Socket Type
E14
Wattage
6.5 W
A+
Energy Consumption per 1000h
6.5 kWh
16 million colours
Colour Temperature
2200-6500 K
Dimmable
Lifetime
25000 hours
Upgradable firmware, instant full light
Power Requirements
AC 220 - 240 V
Package
Hanging box
Warranty
2 years
Diameter
39 mm
Length
117 mm
Type: Light bulb
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
