Philips Hue White and Colour Ambiance B22 Single Lamp
Quicklinx: DL2JWS00 Mfr#: 929001257402
Type: Light bulb
Compatible With: Alexa, Google Assistant
£41.66 ex VAT
£49.99 inc VAT
Get started with the Philips Hue white and color ambiance starter kit and turn on your imagination. Discover the amazing things you can do with white and colored light, with even richer colors for better scene setting.
  • Wake up and go to sleep naturally
    Philips Hue will help get you out of bed the way you like it, helping you to start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise and helps you to wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
  • Create your ambiance with warm white to cool daylight
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, whether it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun or the ice cool daylight of winter.
  • Relax, read, concentrate and energize with light recipes
    Philips Hue can help you to customize your daily routines into moments that you can enjoy. Skip your morning coffee and get ready for the day with cool, bright-white daylight that helps to energize your body and mind. Stay focused with finely tuned bright-white light. Or put your feet up and relax with a soft glow of white light for the perfect end to the day.
  • Set timers for your convenience
    Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on.
  • Installation-free dimming
    Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation.
  • Wirelessly controllable LED bulb
    This LED bulb is wirelessly controllable if you connect it to the Philips Hue bridge for smart control or to the Philips Hue dimmer switch.
Philips Hue White and Color Ambiance - LED light bulb
Light Source Type
LED light bulb
Shape
A19
Socket Type
B22
Wattage
10 W
Wattage Equivalent
60 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
16 million colours
Colour Temperature
2200-6500 K
Luminous Power
800 lumens
Beam Angle
160 degree(s)
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Apple HomeKit, Hue
AC 220 - 240 V
Light Source
LED light bulb
Shape
A19
Socket Type
B22
Wattage
10 W
Wattage Equivalent
60 W
A+
16 million colours
Colour Temperature
2200-6500 K
Colour Rendering Index
80
Luminous Power
800 lumens
Luminous Efficacy
80 lm/W
Beam Angle
160 degree(s)
Dimmable
Lifetime
25000 hours
Upgradable firmware, instant full light, Android compatible, iOS compatible, voice control, controlled via Wi-Fi, remote controlled
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit, Hue
Voice Controlled
Indirect
Package
Hanging box
Warranty
2 years
Diameter
62 mm
Length
110 mm
Type: Light bulb
Brand: Philips
Price Range Ex VAT: 0 - 50
