Philips Hue White and Color Ambiance Starter Kit UK (B22) *V3
Quicklinx: CJ0NWS00 Mfr#: 929001257403
The Philips Hue White and Color Ambiance Starter Kit lets you create your own lighting environment at home using your Apple iOS/ Android device. Simply download the Philips Hue app and create customised white and coloured light settings that match your activity or mood. This starter kit contains three Hue light bulbs and the Hue bridge.
Connect the Hue bridge to your Wi-Fi and control up to 50 Hue bulbs simultaneously via the Hue app on your Apple iOS/ Android device. Hue light bulbs use five times less power than traditional halogen lights, making them an eco-friendly option.
Paint with light
Play with light and choose from 16 million colours in the Hue app to match the light to your mood. The bulbs have been improved with deeper green, cyan and blue for even better scene setting in your home. Use a favourite photo and relive that special moment with splashes of light. Save your favourite light settings and recall them whenever you want with the tap of a finger.
Sync lights with movies
Extend your TV viewing experience to the whole room or lift your gaming experience to the next level. Download the third party apps and discover the amazing things you can do with Philips Hue
Sync lights with music
Sync light to your favorite music and enjoy every beat to the fullest. Transform any room into a dance floor and see how light reacts to your music. Download third party apps and get the party started with Philips Hue.
Apple HomeKit compatible
The Philips Hue white and color ambiance starter kit is compatible with Apple HomeKit technology. Ask Siri to turn on or dim your lights or recall presets without touching a single button. Via third party apps you can even link your lights to other Apple HomeKit enabled devices.
Create your ambiance
Set the right ambience for any moment with a range of beautiful, natural white light. Use the app to set any shade of white light, from cool energizing daylight to relaxing warm white light. So set the mood. Change the ambience. Feel different. Feel better.
Light for your well-being
Light influences our mood, behavior, alertness and routines. Through the app, you can set the light that is optimal for your moment. Philips Hue helps you to energize, concentrate, read and relax. Customize your daily routines into moments you can enjoy. Set the mood. Change the ambiance. Feel different. Feel better.
Wake-up
Ease your sleeping routine and wake up gently for a fresh start of each day. Philips Hue will help get you out of bed in a nice way. The gradually increasing light intensity gives you the feeling you are waking up naturally with sunlight - rather than the rude awakening of an alarm ringing.
Light schedules for home automation
Philips Hue can make it seem like you're home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on.
Away-from-home control
You can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late.
Comfort dimming
Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation.
Smart control
Connect your Philips Hue lights with the bridge and start discovering the endless possibilites. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms, and more for the full Philips Hue experience.
What's in the box?
  • 3x Hue light bulbs
  • 1x Hue bridge
  • 1x Power adaptor for Hue bridge
  • 1x LAN cable to connect the Hue bridge to your router
  • Sync your Philips Hue lights with movies and music
    Extend your TV viewing experience to the whole room or lift your gaming experience to the next level. Sync light to your favorite music and enjoy every beat to the fullest. Turn any room into a dance floor and see how light reacts to your music.
  • Warm white to cool bright daylight
    Set the right ambience for any moment with a range of beautiful, natural white light. Take control and set the ambiance. Not too bright. Not too dark. Just right.
  • Energize, concentrate, read and relax with light
    Light influences mood, behavior, alertness and routines. Set the light that is optimal for your moment. Philips Hue helps you to energize, concentrate, read and relax. Customize your daily routines into moments you can enjoy. Feel different. Feel better.
  • Wake up gently to your personal sunrise
  • Control your lights from anywhere
    You can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late. With geofencing technology, your lights can even welcome you home or switch off automatically when you leave your home. It's all about simplifying your life and giving you peace of mind in smart and useful ways.
Philips Hue White and color - wireless lighting set - LED light bulb
Wireless lighting set
Light Bulb
LED light bulb
