Philips Hue White Ambiance GU10 Single Bulb
Quicklinx: FFSBWS00 Mfr#: 929001953301
Select:
  • GU10
Light your home smarter with Philips Hue
Imagine being able to turn off all your lights with one click. Discover the magic of transforming an entire room from study to home cinema with one tap. Or maybe use your lights to make it seem like you are home when actually you’re not. And when you are home, choose the right light setting to help you concentrate better or relax after a tough day.
  • Control lights with your voice
    Get hands-free control of your lights and use your voice instead! Simple voice commands allow you to control multiple lights in a room or just a single lamp.
  • Set the right mood with warm to cool light
    These bulbs and light fixtures offer different shades of warm to cool light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
  • Get the perfect light recipes for your daily activities
    Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: energize, concentrate, read and relax.
Philips Hue White ambiance - LED spot light bulb - GU10 - 5 W - cool daylight/warm white light - 2200-6500 K
Light Source Type
LED spot light bulb
Socket Type
GU10
Wattage
5 W
Wattage Equivalent
50 W
Energy Efficiency Class
G
Colour of Illumination
Cool daylight/warm white light
Colour Temperature
2200-6500 K
Luminous Power
350 lumens
Dimmable
Intelligent Assistant
Google Assistant, Alexa
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Light Source
LED spot light bulb
Socket Type
GU10
Wattage
5 W
Wattage Equivalent
50 W
G
Energy Consumption per 1000h
5 kWh
Colour Temperature
2200-6500 K
Colour Rendering Index
80
Luminous Power
350 lumens
Dimmable
Lifetime
15000 hours
Switch Cycles
50000
Instant full light, Android compatible, iOS compatible, voice control, remote controlled, controlled via Bluetooth
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Bluetooth, Zigbee
Package
Hanging box
Warranty
2 years
Diameter
50 mm
Length
58 mm
48 g
165 mm x 55 mm x 88 mm / 74 g
-20 °C
45 °C
