Light your home smarter with Philips Hue
Imagine being able to turn off all your lights with one click. Discover the magic of transforming an entire room from study to home cinema with one tap. Or maybe use your lights to make it seem like you are home when actually you’re not. And when you are home, choose the right light setting to help you concentrate better or relax after a tough day.
Control lights with your voice
Get hands-free control of your lights and use your voice instead! Simple voice commands allow you to control multiple lights in a room or just a single lamp. -
Set the right mood with warm to cool light
These bulbs and light fixtures offer different shades of warm to cool light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs. -
Get the perfect light recipes for your daily activities
Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: energize, concentrate, read and relax.
- Philips Hue White ambiance - LED light bulb with reflector - GU10 - 5 W - cool daylight/warm white light - 2200-6500 K
- Light Source Type
- Socket Type
- GU10
- Wattage
- 5 W
- Wattage Equivalent
- 50 W
- Light Bulb Energy Efficiency Class
- A+
- Colour of Illumination
- Cool daylight/warm white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 350 lumens
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
Light Source
- Socket Type
- GU10
- Wattage
- 5 W
- 50 W
- A+
- 2200-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 350 lumens
- Dimmable
- Lifetime
- 15000 hours
- Switch Cycles
- 50000
- Instant full light, Android compatible, iOS compatible, voice control, remote controlled, controlled via Bluetooth
Power Requirements
- Voltage Required
- AC 220 - 240 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Bluetooth, Zigbee
- Package
- Hanging box
- Warranty
- 2 years
- Diameter
- 50 mm
- Length
- 58 mm
- 48 g
- Shipping Dimensions (WxDxH) / Weight
- 165 mm x 55 mm x 88 mm / 74 g
- -20 °C
- 45 °C
