Light for your daily routines
Light influences the mood and behavior. Philips Hue can help you to customize your daily routines into moments you can enjoy. Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Stay focussed with finely tuned bright white light. Or put your feet up and relax with a soft glow of white light for the perfect end of the day. -
Full control with Hue bridge
Connect your Philips Hue lights with the bridge to unlock the endless possibilites of the system. -
Create your ambiance
Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun, or the ice cool daylight of winter. -
Wake up and go to sleep
Philips Hue will help get you out of bed the way you like it, helping you start your day feeling refreshed. The light brightness increases gradually mimicking the effect of sunrise and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day, the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep. Connection with the Philips Hue bridge required for this functionality. -
Timers for your convenience
Philips Hue can make it seem like you're home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on. Connection with the Philips Hue bridge required for this functionality
- Philips Hue - LED light bulb with reflector - GU10 - 5.5 W - cold/warm white light - 2200-6500 K
- Light Source Type
- Socket Type
- GU10
- Wattage
- 5.5 W
- Light Bulb Energy Efficiency Class
- A+
- Colour of Illumination
- Cold/warm white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 250 lumens
- Beam Angle
- 46 degree(s)
- Dimmable
- Voltage Required
- AC 220 - 240 V
Light Source
- Socket Type
- GU10
- Wattage
- 5.5 W
- A+
- 2200-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 250 lumens
- Luminous Efficacy
- 46 lm/W
- Beam Angle
- 46 degree(s)
- Starting Time
- 2 sec
- Dimmable
- Lifetime
- 25000 hours
- Upgradable firmware
Power Requirements
- Voltage Required
- AC 220 - 240 V
- Warranty
- 2 years
- 57 mm
- Diameter
- 50 mm
