Philips Hue White Ambiance GU10 Bulb
Quicklinx: D6D7WS00 Mfr#: 929001257601
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
Stock Status: Clearance
£20.83 ex VAT
£24.99 inc VAT
Express delivery Order within the next 14 hours for delivery on Monday
  • Light for your daily routines
    Light influences the mood and behavior. Philips Hue can help you to customize your daily routines into moments you can enjoy. Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Stay focussed with finely tuned bright white light. Or put your feet up and relax with a soft glow of white light for the perfect end of the day.
  • Full control with Hue bridge
    Connect your Philips Hue lights with the bridge to unlock the endless possibilites of the system.
  • Create your ambiance
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun, or the ice cool daylight of winter.
  • Wake up and go to sleep
    Philips Hue will help get you out of bed the way you like it, helping you start your day feeling refreshed. The light brightness increases gradually mimicking the effect of sunrise and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day, the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep. Connection with the Philips Hue bridge required for this functionality.
  • Timers for your convenience
    Philips Hue can make it seem like you're home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on. Connection with the Philips Hue bridge required for this functionality
Philips Hue - LED light bulb with reflector
Light Source Type
Socket Type
GU10
Wattage
5.5 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Cold/warm white light
Colour Temperature
2200-6500 K
Luminous Power
250 lumens
Beam Angle
46 degree(s)
Dimmable
AC 220 - 240 V
Light Source
Socket Type
GU10
Wattage
5.5 W
A+
Colour Temperature
2200-6500 K
Colour Rendering Index
80
Luminous Power
250 lumens
Luminous Efficacy
46 lm/W
Beam Angle
46 degree(s)
Starting Time
2 sec
Dimmable
Lifetime
25000 hours
Upgradable firmware
Power Requirements
AC 220 - 240 V
Warranty
2 years
57 mm
Diameter
50 mm
Type: Light bulb
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
