Philips Hue White Ambiance E27 Single Lamp
Quicklinx: DL67WS00 Mfr#: 929001200103
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
£20.83 ex VAT
£24.99 inc VAT
Philips hue combines brilliant LED light with intuitive technology. It will surely change the way you use light. Forever. Experiment with shades of white, from invigorating blue/white to cozy yellow/white. Or play with all the colors in the spectrum. Hue can wake you up. Help protect your home. Relive your favorite memories. Improve your mood. Even keep you informed about the weather. Not just stunning, hue is smart too. And it's tailored for you.
  • Light for your daily routines
    Light influences the mood and behavior. Philips Hue can help you to customize your daily routines into moments you can enjoy. Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Stay focussed with finely tuned bright white light. Or put your feet up and relax with a soft glow of white light for the perfect end of the day.
  • Full control with Hue bridge
    Connect your Philips Hue lights with the bridge to unlock the endless possibilites of the system.
  • Create your ambiance
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun, or the ice cool daylight of winter.
  • Wake up and go to sleep
    Philips Hue will help get you out of bed the way you like it, helping you start your day feeling refreshed. The light brightness increases gradually mimicking the effect of sunrise and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day, the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep. Connection with the Philips Hue bridge required for this functionality.
  • Timers for your convenience
    Philips Hue can make it seem like you're home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on. Connection with the Philips Hue bridge required for this functionality
Philips Hue - LED light bulb
Light Source Type
LED light bulb
Shape
A19
Socket Type
E27
Wattage
9.5 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Cold/warm white light
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Dimmable
Intelligent Assistant
Indirect
Platform
Hue
Communications Technology
Zigbee
Light Source
LED light bulb
Shape
A19
Socket Type
E27
Wattage
9.5 W
A+
Energy Consumption per 1000h
10 kWh
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Dimmable
Lifetime
25000 hours
Upgradable firmware
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Communications Type
Product-to-product
Zigbee
Voice Controlled
Indirect
Warranty
2 years
Length
110 mm
-10 °C
45 °C
Type: Light bulb
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
