Philips Hue White Ambiance E14 Twin Pack
Quicklinx: D5MLWS00 Mfr#: 929001301402
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
Hurry, only 3 left in stock!
£33.33 ex VAT
£39.99 inc VAT
Express delivery Order within the next 19 hours for delivery on Thursday
Ease your sleeping routine and wake up gently for a fresh start each day. Philips Hue will help get you out of bed in a nice way. The gradually increasing light intensity gives you the feeling that you are waking up naturally with sunlight - rather than the rude awakening of an alarm ringing.
  • Wake up and go to sleep
    Philips Hue will help get you out of bed the way you like it, helping you to start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise and helps you to wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
  • Create your ambience
    Set the right ambience for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, whether it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun or the ice cool daylight of winter.
  • Light for your daily routines
    Light influences the mood and behavior. Philips Hue can help you to customise your daily routines into moments that you can enjoy. Skip your morning coffee and get ready for the day with cool, bright-white daylight that helps to energize your body and mind. Stay focused with finely tuned bright-white light. Or put your feet up and relax with a soft glow of white light for the perfect end to the day.
  • Timers for your convenience
    Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on.
  • Installation-free dimming
    Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation.
Philips Hue White ambiance - LED light bulb
Light Bulb Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Shape
B39
Socket Type
E14
Wattage
6 W
Wattage Equivalent
40 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Cool daylight/warm white light
Colour Temperature
2200-6500 K
Luminous Power
470 lumens
Dimmable
AC 220 - 240 V
Packaged Quantity
Android compatible, iOS compatible, remote controlled
Light Bulb
LED light bulb
Shape
B39
Socket Type
E14
Wattage
6 W
Wattage Equivalent
40 W
A+
Energy Consumption per 1000h
6 kWh
Colour Temperature
2200-6500 K
Luminous Power
470 lumens
Dimmable
Lifetime
25000 hours
Upgradable firmware
Power Requirements
AC 220 - 240 V
Package
Hanging box
Warranty
2 years
Diameter
39 mm
Length
117 mm
Type: Light bulb
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
