Philips Hue White Ambiance E14 Bulb
Quicklinx: D5MCWS00 Mfr#: 929001301401
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
£20.83 ex VAT
£24.99 inc VAT
Add a Philips Hue White Ambiance candle to your system and enhance your home with shades of white lights. This bulb helps you to wake up, relax, read, concentrate or energize.
  • Wake up and go to sleep
    Philips Hue will help get you out of bed the way you like to, helping you start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise, and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock.
  • Create your ambiance
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of summer sun or the ice cool daylight of winter.
  • Light for your daily routines
    Light influences your mood and behavior. Philips Hue can help you to customize your daily routines into moments you can enjoy. Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind.
Philips Hue White ambiance - LED light bulb
Light Bulb Type
LED light bulb
Shape
B39
Socket Type
E14
Wattage
6 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
White light
Colour Temperature
2200-6500 K
Light Bulb
LED light bulb
Shape
B39
Socket Type
E14
Wattage
6 W
A+
Energy Consumption per 1000h
6 kWh
White light
Colour Temperature
2200-6500 K
Lifetime
25000 hours
Warranty
2 years
Diameter
39 mm
Length
117 mm
Type: Light bulb
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
