Philips Hue White Ambiance A60 E27 Twin Pack
Quicklinx: D5M6WS00 Mfr#: 929001200163
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
£33.33 ex VAT
£39.99 inc VAT
Philips Hue will help get you out of bed the way you like to, helping you start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise, and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of summer sun or the ice cool daylight of winter.
  • Wake up and go to sleep naturally
  • Create your ambience with warm white to cool daylight
  • Relax, read, concentrate and energize with light recipes
    Light influences the mood and behavior. Philips Hue can help you to customise your daily routines into moments you can enjoy. Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Stay focused with finely tuned bright white light. Or put your feet up and relax with a soft glow of white light for the perfect end to the day.
  • Smart control, home and away
    With the Philips Hue iOS and Android apps, you can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late.
  • Set timers for your convenience
    Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on.
Philips Hue White ambiance - LED light bulb
Packaged Quantity
2 (specifications are for single item)
Dimmer
Light Bulb
LED light bulb
Shape
A60
Socket Type
E27
Wattage
9.5 W
Colour of Illumination
Cool daylight/warm white light
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Lifetime
25000 hours
Instant full light, Android compatible, iOS compatible
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Internet of Things (IoT) Hub Compatibility
Philps Hue Bridge
Platform
Hue
Warranty
2 years
Diameter
62 mm
Length
110 mm
-10 °C
45 °C
Type: Light bulb
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
