Philips Hue White Ambiance 3 Bulb E27 + Switch Starter Kit
Quicklinx: D5M7WS00 Mfr#: 929001200161
Type: Wireless lighting set
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
£99.99 ex VAT
£119.98 inc VAT
Always create the perfect ambience with this Philips Hue smart light starter kit. It includes three bulbs that you can turn on from your phone or tablet, so you can arrive to a bright, cosy home at the end of the day. As they’re white bulbs, you can be confident that they’ll always produce clear light. Each bulb has a simple screw fitting and a 25,000 hour lifespan too. It’s easy to set a timer as well, so when you’re sunning yourself on holiday, it’ll still look like you’re at home. The bulbs even work with the Apple HomeKit and Amazon Echo smart speakers, letting you control the lighting with simple voice commands, so you’ll never need to lift a finger.
The kit also includes the Philips Bridge hub, needed for the lights to work, and a wireless dimmer switch. You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
Key Features
  • Smart light bulb – control from your phone or tablet
  • White bulb - provides clear lighting for your home
  • Screw fitting with 25,000 hour lifespan
  • Schedule a timer to turn lights on automatically
  • Works with Google Home, Amazon Alexa and Apple HomeKi
Philips Hue White ambiance Starter kit - wireless lighting set - LED light bulb x 3
Light Bulb Type
3 x LED light bulb
Supported Light Bulbs Qty
50
Total Wattage
28.5 W
Shape
A60
Socket Type
E27
Wattage
9.5 W
Colour of Illumination
Cool white/warm white light
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
AC 100 - 240 V
Frequency Required
50 - 60 Hz
50
Total Wattage
28.5 W
iOS compatible, upgradable firmware
Light Bulb
3 x LED light bulb
Shape
A60
Socket Type
E27
Wattage
9.5 W
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Lifetime
25000 hours
Upgradable firmware, instant full light
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
1 x CR2450
Internet of Things (IoT)
Internet of Things (IoT) Hub
Included
Internet of Things (IoT) Hub Compatibility
Philps Hue Bridge
Platform
Apple HomeKit, Google Home, Hue
Communications Type
Product-to-product
Communications Technology
Zigbee
Intelligent Assistant Compatible
Alexa
Voice Controlled
Indirect
Wall bracket, power adapter, wireless bridge, network cable, dimmer switch, battery
Warranty
2 years
Dimensions & Weight Details
Light bulb height: 110 mm x diameter: 62 mm , Wireless bridge - width: 88 mm x depth: 88 mm x height: 26 mm , Dimmer switch - width: 35 mm x depth: 11 mm x height: 117 mm , Wall bracket - width: 70 mm x depth: 14 mm x height: 114 mm - 67 g
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 50 - 100
