Philips Hue White A60 E27 Twin Pack
Quicklinx: D5MBWS00 Mfr#: 929001137062
  • Make it look like you're home with smart lights
    Use the Philips Hue app to schedule light routines whenever you're away. Your smart lights will turn on at the times you've selected - and sometimes a few minutes before or after - to truly mimic your presence in the house.
  • Come home to a house filled with light
    Set your Philips Hue app to recognize when you're nearing home. Before you even step out of your car or walk up the path, your selected smart lights turn on automatically.
  • Control away from home with the Hue app
    The Hue app gives you complete control over your lights, even if you're not home. Switch your lights off and on remotely using just the app to ensure your home is always lit the way you want it.
  • Installation-free dimming
    Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation
  • Control lights with your voice
    When connected to the Hue Bridge, you can pair your lights with Alexa, Apple HomeKit, and the Google Assistant and control your lights using just your voice. Simple voice commands let you turn your lights on and off, dim or brighten your lights, and even set a light scene.
Philips Hue White - LED light bulb
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Shape
A60
Socket Type
E27
Wattage
9.5 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
806 lumens
Dimmable
Intelligent Assistant
Alexa
Platform
Apple HomeKit, Google Home, Hue
AC 220 - 240 V
Packaged Quantity
Light Source
LED light bulb
Shape
A60
Socket Type
E27
Wattage
9.5 W
A+
Warm white light
Colour Temperature
2700 K
Luminous Power
806 lumens
Dimmable
Lifetime
25000 hours
Upgradable firmware, instant full light, Android compatible, iOS compatible, remote controlled
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Communications Type
Product-to-product
Intelligent Assistant Compatible
Alexa
Warranty
2 years
Diameter
62 mm
Length
110 mm
-10 °C
45 °C
