Use thousands of shades of warm-to-cool white light with these B22 smart bulbs, whose bayonet bases fit most standard fixtures. Wireless dimming lets you set the right mood instantly.
Set the right mood with warm to cool white light
These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs. -
Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device. -
Control lights with your voice
Philips Hue works with voice assistants when paired with a compatible device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp. -
Get the perfect light recipes for your daily activities
Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
- Philips Hue White ambiance 1100 - LED light bulb - shape: A60 - B22 - 11 W - warm white to cool white light - 2200-6500 K (pack of 2)
- Light Source Type
- LED light bulb
- Packaged Quantity
- 2 (specifications are for single item)
- Shape
- A60
- Socket Type
- B22
- Wattage
- 11 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Warm white to cool white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 1055 lumens
- Dimmable
- Intelligent Assistant
- Cortana, Google Assistant, Alexa - indirect
- Platform
- Apple HomeKit
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Packaged Quantity
Light Source
- LED light bulb
- Shape
- A60
- Socket Type
- B22
- Wattage
- 11 W
- F
- Energy Consumption per 1000h
- 11 kWh
- Power Factor
- 0.5
- 2200-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 1055 lumens
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Instant on, upgradable software
Power Requirements
- Voltage Required
- AC 220 - 240 V
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Apple HomeKit
- Supported Host Device Platform
- iOS, Android
- Bluetooth, Zigbee
- Voice Controlled
- Indirect
- Warranty
- 2 years / 30 days return
- Diameter
- 60 mm
- Length
- 110 mm
- 72 g
- Shipping Dimensions (WxDxH) / Weight
- 14.6 cm x 7.2 cm x 17.4 cm / 270 g
- -20 °C
- 45 °C
