Make a statement with a round LED globe bulb featuring a coiled filament design. Vintage in style but still modern, filament bulbs can do everything other smart bulbs can do, including dimming and brightening.
Vintage design meets modern capabilities
Capture the popular look of Edison bulbs, featuring a distinct glowing inner coil and transparent globe, with smart filament bulbs. These smart retro style LED bulbs combine the look and feel of simple vintage design with the power of Philips Hue smart lighting. -
Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device. -
Control lights with your voice
Get hands-free control of your lights and use your voice instead! Simple voice commands allow you to control multiple lights in a room, or just a single lamp. Works with Amazon Alexa and the Google Assistant. -
Set the right mood with soft white light
Hue bulbs and light fixtures use a soft white light. Dimmable from bright daylight to low nightlights, these smart lights allow you to fill your home with just the right level of warm light when you need it.
- Philips Hue - LED filament light bulb - shape: G125 - B22 - 7 W - soft white light - 2100 K - transparent
- Light Source Type
- Transparent
- Shape
- G125
- Socket Type
- B22
- Wattage
- 7 W
- Wattage Equivalent
- 40 W
- Energy Efficiency Class
- G
- Colour of Illumination
- Soft white light
- Colour Temperature
- 2100 K
- Luminous Power
- 550 lumens
- Dimmable
- Intelligent Assistant
- Cortana, Google Assistant, Alexa
- Platform
- Apple HomeKit
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
Light Source
- Shape
- G125
- Socket Type
- B22
- Wattage
- 7 W
- 40 W
- G
- Energy Consumption per 1000h
- 7 kWh
- Soft white light
- 2100 K
- Colour Rendering Index
- 80
- Luminous Power
- 550 lumens
- Dimmable
- Lifetime
- 15000 hours
- Switch Cycles
- 50000
- Instant full light, Android compatible, iOS compatible, voice control, app-controlled, retro design
Power Requirements
- Voltage Required
- AC 220 - 240 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Apple HomeKit
- Bluetooth, Zigbee
- Body Colour
- Transparent
- Warranty
- 2 years
- Diameter
- 125 mm
- Length
- 197 mm
- 115 g
- Shipping Dimensions (WxDxH) / Weight
- 140 mm x 140 mm x 240 mm / 285 g
- -10 °C
- 45 °C
