The Philips Hue Tap Wireless Switch puts control of your Hue light bulbs at your fingertips when your iOS device is charging or in use. In addition to turning on the lights, the four buttons let you instantly select favourite scene creations that you've previously set up with the Hue app.
- The fastest way to recall your favourite Hue scenes
- Mount Tap Switch on any wall or use it as a remote
- No batteries required - Tap Switch is powered by your touch
- Fast, simple installation with no wires
- Freedom to place anywhere - on the wall near your door or on the table near your chair
- One button is usable for lights off
The Hue Tap Switch is powered by your touch - no need for batteries or wires.
What's in the box?
- Philips Hue Tap Switch
- Wall bracket with adhesive tape
- User instructions
Recall your favorite scenes
With the Tap switch you can recall 4 different preset light scenes or switch lights on/off by pressing a button. Use the app to setup your personal scenes or scenes that are created by lighting designers. You can use the Tap switch without opening the Philips Hue App and even when your Wi-Fi is disconnected. -
Mount or use remotely
Mount the Tap switch anywhere with the included mounting plate, or detach it and carry it with you as you move through your home. Set the right mood for every moment of the day. -
Use as a remote control
You can also use Philips Hue tap switch as a remote control for your comfort. -
Powered by your touch
The Tap switch is powered by kinetic energy, which means that when you press the light switch you generate sufficient energy to control your smart lights.
- Philips Hue Tap - light switch - ZigBee, 802.15.4
- Product Type
- Light switch
- Functions
- Light control
- Max Supported Devices
- 4
- Connectivity
- Wireless - ZigBee, 802.15.4
- Frequency Band
- 2400 - 2483.5 Mhz
- 2-year warranty
- 7.5 cm x 7.5 cm x 2.5 cm
- Product Type
- Light switch
- Functions
- Light control
- 4
- Connectivity Technology
- Wireless - ZigBee
- Frequency Band
- 2400 - 2483.5 Mhz
- Warranty
- 2-year warranty
- 7.5 cm
- 7.5 cm
- 2.5 cm
- 90 g
- 0 °C
- 40 °C
- 0 - 80% (non-condensing)
