Your basket is empty
Philips Hue Tap Wireless Switch
Quicklinx: BZD5WS00 Mfr#: 929001115212
The Philips Hue Tap Wireless Switch puts control of your Hue light bulbs at your fingertips when your iOS device is charging or in use. In addition to turning on the lights, the four buttons let you instantly select favourite scene creations that you've previously set up with the Hue app.
  • The fastest way to recall your favourite Hue scenes
  • Mount Tap Switch on any wall or use it as a remote
  • No batteries required - Tap Switch is powered by your touch
  • Fast, simple installation with no wires
  • Freedom to place anywhere - on the wall near your door or on the table near your chair
  • One button is usable for lights off
The Hue Tap Switch is powered by your touch - no need for batteries or wires.
What's in the box?
  • Philips Hue Tap Switch
  • Wall bracket with adhesive tape
  • User instructions
Philips Hue Tap - light switch
Light switch
Functions
Light control
Max Supported Devices
4
Wireless - ZigBee, 802.15.4
Frequency Band
2400 - 2483.5 Mhz
2 years warranty
7.5 cm x 7.5 cm x 2.5 cm
Light switch
Functions
Light control
4
Wireless - ZigBee
Frequency Band
2400 - 2483.5 Mhz
Warranty
2 years warranty
7.5 cm
7.5 cm
2.5 cm
90 g
0 - 80% (non-condensing)
