Product
Philips Hue Tap Wireless Lighting Smart Switch
Quicklinx: CJ0DWS00 Mfr#: 929001115222
Philips Hue Tap is the first wireless smart switch that controls your Philips Hue lights,
powered by your touch. Connect it to your Philips Hue Bridge and control 4 different
Philips Hue light scenes without using your smart device.
Recall your favourite Philips Hue scenes
  • 4 buttons to activate 4 different scenes
Place it anywhere
  • Place anywhere you need a light switch
Use as a remote control
  • Wireless switch and remote control in one
Powered by your touch
  • Kinetic energy -- no batteries needed
Easy, reliable and future-proof system
  • Connect up to 50 Philips Hue lights
What's in the box?
  • 1x Hue Tap switch
Type: Wireless light switch
Compatible With: Alexa
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
