Philips Hue Tap
Quicklinx: DL5QWS00 Mfr#: 929001115262
  • Recall your favorite scenes
    With the Tap switch you can recall 4 different preset light scenes or switch lights on/off by pressing a button. Use the app to setup your personal scenes or scenes that are created by lighting designers. You can use the Tap switch without opening the Philips Hue App and even when your Wi-Fi is disconnected.
  • Mount or use remotely
    Mount the Tap switch anywhere with the included mounting plate, or detach it and carry it with you as you move through your home. Set the right mood for every moment of the day.
  • Use as a remote control
    You can also use Philips Hue tap switch as a remote control for your comfort.
  • Powered by your touch
    The Tap switch is powered by kinetic energy, which means that when you press the light switch you generate sufficient energy to control your smart lights.
Philips Hue Tap - light switch
Light switch
Functions
Light control
Internet of Things (IoT) Platform
Hue
Intelligent Assistant
Indirect
Wireless - ZigBee, 802.15.4
Frequency Band
2400 - 2483.5 Mhz
7.5 cm x 7.5 cm x 2.5 cm
Light switch
Functions
Light control
Wireless - ZigBee
Max Range Indoors
30 m
Frequency Band
2400 - 2483.5 Mhz
Wall mountable, kinetic energy, battery free
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Communications Type
Product-to-product
Communications Technology
Zigbee
Voice Controlled
Indirect
Warranty
7.5 cm
7.5 cm
2.5 cm
90 g
0 - 80% (non-condensing)
