Recall your favorite scenes
With the Tap switch you can recall 4 different preset light scenes or switch lights on/off by pressing a button. Use the app to setup your personal scenes or scenes that are created by lighting designers. You can use the Tap switch without opening the Philips Hue App and even when your Wi-Fi is disconnected. -
Mount or use remotely
Mount the Tap switch anywhere with the included mounting plate, or detach it and carry it with you as you move through your home. Set the right mood for every moment of the day. -
Use as a remote control
You can also use Philips Hue tap switch as a remote control for your comfort. -
Powered by your touch
The Tap switch is powered by kinetic energy, which means that when you press the light switch you generate sufficient energy to control your smart lights.
- Philips Hue Tap - light switch - ZigBee, 802.15.4
- Product Type
- Light switch
- Functions
- Light control
- Internet of Things (IoT) Platform
- Hue
- Intelligent Assistant
- Indirect
- Connectivity
- Wireless - ZigBee, 802.15.4
- Frequency Band
- 2400 - 2483.5 Mhz
- 2-year warranty
- 7.5 cm x 7.5 cm x 2.5 cm
- Product Type
- Light switch
- Functions
- Light control
- Connectivity Technology
- Wireless - ZigBee
- Max Range Indoors
- 30 m
- Frequency Band
- 2400 - 2483.5 Mhz
- Wall mountable, kinetic energy, battery free
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Communications Type
- Product-to-product
- Communications Technology
- Zigbee
- Voice Controlled
- Indirect
- Warranty
- 2-year warranty
- 7.5 cm
- 7.5 cm
- 2.5 cm
- 90 g
- 0 °C
- 40 °C
- 0 - 80% (non-condensing)
