Product
Brand
Philips Hue Starter Kit UK (B22) *V2
Quicklinx: BZCXWS00 Mfr#: 929001142102
Your personal wireless lighting system
Enhance your everyday life. Philips Hue can welcome you home. Wake you up. Get you energized. Make you feel safe. Improve your mood. Enhance your entertainment experience. It can even keep you informed about the weather or incoming calls. The possibilities are endless once you start exploring.
Turn on your peace of mind
Philips Hue welcomes you home and lets you control your lights from your bedroom to your backyard. You can automate your lights completely to make it seem like you’re home when you’re not. With geofencing technology, your lights can even welcome you home or switch off automatically when you leave your home. It’s all about simplifying your life and giving you peace of mind in smart and useful ways.
Turn on your moments
Philips Hue can wake you up and help you energize, read, concentrate and relax. Customize your daily routines into moments you can enjoy. Set the mood. Change the ambiance. Feel the difference. Feel better. Set the right ambiance for any moment with a range of beautiful, natural white light. Use the app to set any shade of white light, from cool energizing daylight to relaxing warm white light.
Turn on your imagination
Turn your everyday lighting into an extraordinary experience. Play with colors or sync lights with your music, TV and games for an immersive effect. The possibilities are endless once you start exploring. And with hundreds of apps to choose from, the only real limit is your imagination.
Philips Hue Starter Kit - wireless lighting set - LED light bulb x 3
Wireless lighting set
Light Bulb Type
3 x LED light bulb
Supported Light Bulbs Qty
50
Total Wattage
27 W
Dimmer
Shape
A60
Socket Type
B22
Wattage
9 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
806 lumens
Beam Angle
160 degree(s)
50
Total Wattage
27 W
Dimmer
Android compatible, iOS compatible
Light Bulb
3 x LED light bulb
Shape
A60
Socket Type
B22
Wattage
9 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
806 lumens
Beam Angle
160 degree(s)
Lifetime
25000 hours
Upgradable firmware, instant full light
Power adapter, wireless bridge, network cable
Warranty
2 years
Dimensions & Weight Details
Wireless bridge height: 2.5 cm x diameter: 10 cm , Light bulb height: 11 cm x diameter: 6.2 cm
