Philips Hue LightStrip Plus Extension Set
Quicklinx: CHYXWS00 Mfr#: 915005108901
Type: Light strip
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
14 in stock
£16.66 ex VAT
£19.99 inc VAT
Light up your home with the Philips Hue Lightstrip Plus 1m Extension Set. The most most flexible light source imaginable, get creative and use it to set the mood in a room - highlighting architectural features with smooth, indirect light. Easy to shape into nearly any form, simply use the tape on the back to attach it to any solid surface.
Simply start with the Philips Hue Lightstrip Plus and extend it by up to ten metres with additional 1 m extension strips.
Highlights
  • One-metre extension for Philips Hue Lightstrip Plus
  • Connect wirelessly to the Philips Hue bridge to control from your iPhone, iPad or iPod touch
  • Create a personal lighting scheme in each room
  • Up to 16 million colours
  • 1600 lumen output
  • Adheres to any solid surface
  • Shape, bend, and cut to size
You can shape the strip in nearly any form and use the tape on the back to attach it to any solid surface.
What's in the box?
  • Philips Hue Lightstrip Plus 1m Extension Set
  • Quick Start guide
  • Legal manual
  • Note: This product requires the Philips HUE bridge to function.
  • Shape, bend and extend
    You can shape it in nearly any form and use the tape on the back to attach it to virtually any solid surface. If needed, you can cut the strip to size on the scissor markings. Integrate Lightstrip Plus into furniture, under kitchen cabinets or highlight architectural features with smooth, indirect light. Hue Lightstrips Plus is the most versatile and robust light source that will bring your room to life.
  • Paint with light
    Play with light and choose from 16 million colors in the Hue app to match the light to your mood. Philips Hue Lightstrip Plus gives you full color consistency from the first to the last extension. Use a favorite photo and re-live that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Sync light to music and movies
    Extend your TV viewing experience to the whole room or lift your gaming experience to the next level. Download a third party app and discover the amazing things you can do with Philips Hue. Or sync light to your favorite music and enjoy every beat to the fullest. Turn any room into a dance floor and see how light reacts to your music. Download one of the third party apps and get the party started with Philips Hue.
  • Create your ambiance
    Set the right ambience for any moment with a range of beautiful, natural white light. Use the app to set any shade of white light, from cool energizing daylight to relaxing warm white light. Take control and set the ambiance. Not too bright. Not too dark. Just right.
  • Light for your well-being
    Light influences the mood, behavior, alertness and routines. Through the app, you can set the light that is optimal for your moment. Philips Hue helps you to energize, concentrate, read and relax. Customize your daily routines into moments you can enjoy. Feel different. Feel better.
Philips Hue Plus extension - light strip - LED
Light strip
Light Bulb Type
LED
Dimmer
Built-in LED Energy Efficiency Class
A
Colour of Illumination
16 million colours
Luminous Power
800 lumens
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Light strip
Dimmer
Double insulated, extendable, Android compatible, iOS compatible, ZigBee Light Link, Wi-Fi controlled, 16 million changeable colours, 3M adhesive tape mounting
Light Bulb
LED
Built-in LED Lamp
A
16 million colours
Luminous Power
800 lumens
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Product Material
Synthetics
Power adapter
IP21
Warranty
2 years
0.3 cm
1.1 cm
Length
100 cm
53 g
Type: Light strip
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
