Philips Hue LightStrip Plus Extension Set
Quicklinx: CHYXWS00 Mfr#: 915005108901
Type: Light strip
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
Stock Status: Clearance
19 left in stock
£14.99 ex VAT
£17.98 inc VAT
Express delivery Order within the next 4 hours for delivery tomorrow
Light up your home with the Philips Hue Lightstrip Plus 1m Extension Set. The most most flexible light source imaginable, get creative and use it to set the mood in a room - highlighting architectural features with smooth, indirect light. Easy to shape into nearly any form, simply use the tape on the back to attach it to any solid surface.
Simply start with the Philips Hue Lightstrip Plus and extend it by up to ten metres with additional 1 m extension strips.
Highlights
  • One-metre extension for Philips Hue Lightstrip Plus
  • Connect wirelessly to the Philips Hue bridge to control from your iPhone, iPad or iPod touch
  • Create a personal lighting scheme in each room
  • Up to 16 million colours
  • 1600 lumen output
  • Adheres to any solid surface
  • Shape, bend, and cut to size
You can shape the strip in nearly any form and use the tape on the back to attach it to any solid surface.
What's in the box?
  • Philips Hue Lightstrip Plus 1m Extension Set
  • Quick Start guide
  • Legal manual
  • Note: This product requires the Philips HUE bridge to function.
  • Paint with light
    Play with light and choose from millions of colors. Use a favorite photo and re-live that special moment with splashes of light.
  • Create your ambiance
    Set the right ambiance for any moment with a range of beautiful, natural light.
  • Sync light to music and movies
    Extend your TV viewing experience to the whole room or lift your gaming experience to the another level.
Philips Hue Plus extension - light strip - LED
Light strip
Light Source Type
LED
Dimmer
Built-in LED Energy Efficiency Class
A
Colour of Illumination
16 million colours
Luminous Power
800 lumens
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Light strip
Dimmer
Double insulated, extendable, Android compatible, iOS compatible, ZigBee Light Link, Wi-Fi controlled, 16 million changeable colours, 3M adhesive tape mounting
Light Source
LED
Built-in LED Lamp
A
16 million colours
Luminous Power
800 lumens
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Product Material
Synthetics
Power adapter
IP21
Warranty
2 years
0.3 cm
1.1 cm
Length
100 cm
53 g
Type: Light strip
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
