Philips Hue Iris Clear - Single
Quicklinx: CHZ6WS00 Mfr#: 915004315901
Light your room to set the mood with the unique Friends of Hue LivingColors Iris, from Philips. Designed to work with Philips Hue systems, this wireless-enabled mood light connects to your Wi-Fi to allow you you to control the atmosphere in your room through the Philips Hue app for iOS and Android. Hue lamps and light bulbs can be grouped together so you can set the mood in a room in one go, with up to 50 lights on one network.
Colour your life
With 16 million colour variations to choose from, you can set Iris to the mood that suits you, so you can wash your walls with a blue ocean glow or illuminate a favourite feature. Colours can be saved as 'Scenes', so you can revisit your favourites, or you can choose from the available presets. These 'light recipes' have been proven to create the perfect atmosphere for your needs. The 'Reading' recipe is ideal for curling up with a book, while 'Relax' provides a soothing glow. 'Concentrate' will help you stay alert when working, while 'Energise' bathes you in vibrant lights to revitalise you.
Programmable
Iris works as more than just a colourful lamp. It can be tailored to your life, with alarms, timers and alerts, so you can set Hue to wake you up with a soft sunrise glow, or to turn all of your Hue lights off at bedtime. Hue lights can flash at you to let you know when your food is ready to come out of the oven, or to let you know when your favourite TV show is starting. You can set your lights to come on when you're away, to deter thieves, or control them remotely via the portal, from anywhere in the world. Geofencing technology can be used to turn your Hue lights on as you enter the door. Hue can even be linked to data feeds via the IFTTT (If This Then That) service, to give you a visual alert when you get an important email or when the weather changes.
Apps to help you unlock more
With additional iOS and Android apps, you can get even more out of your Hue. Ambilight+hue for both iOS and Android works with Philips Ambilight TVs (2011 model or newer, type number 6 or higher in xxPFLxxx6) to match the mood in your living room to the scenes on TV, creating a more immersive experience. Ambify for iOS and hue Disco for Android make Hue react to music, providing you with an instant dance floor.
  • Control from smart devices
    Simply sync your lights to your existing Philips hue bridge. Once that is done, you can control your lights wirelessly from anywhere in your house. Be it from the living room, the dining table or from your bedroom, your smart device can control any light connected to the bridge.
  • Expand your ecosystem
    You can connect up to 50 bulbs or lamps to your existing Philips hue bridge. Simply begin with any of the available extension kits and start adding Philips hue bulbs or Philips Friends of hue products in any combination. With a tap of your finger, you can now control any connected lighting in your home.
  • Create your own light settings
    Use your favorite picture to generate the perfect color scene for special occasions. Go back in time and relive those moments by uploading your own picture and tuning the lights accordingly. Add up to 50 lights to every setting, and recall with a simple tap of the finger.
  • Timer function
    The timer function not only lets you pre-set what time your Friends of hue product comes on, for light when you arrive home in the evening, but also lets you change your lights gradually over time. Use it to turn your Friends of hue product into your wake-up light. Pre-set it to increase the brightness gradually to bring you out of your sleep softly and gently compared with the sudden beep or ring of a conventional alarm clock. At night, you can pre-set the timer to turn your lights off gradually to help you fall asleep naturally.
  • Light dynamics
    The hue ecosystem is fully open for developers. There are an ever-growing number of applications being developed for hue within this community. This has resulted in creative and dynamic lighting schemes opening possibilities of syncing your lights to your favorite music, to get the party kicking.
  • Safety and security
    Make it look like you are at home even when you are away! With online access and at the tap of your smart device's menu screen, you can now control your home lighting. Convenience and peace of mind.
  • Match any interiors
    Philips Friends of hue Iris is designed to create indirect ambient lighting and is a perfect way to highlight your favorite furniture or architectural features in your home. Timeless and distinctive in design, placed on the floor or on your favorite furniture, it will blend seamlessly with your interiors. And because it is a plug-based product, you can easily move it around and place it where a power socket is available.
Philips Hue Iris - decoration lamp - LED
Decoration lamp
Light Bulb Type
LED
Dimmer
Clear
Wattage
10 W
Luminous Power
210 lumens
Beam Angle
120 degree(s)
AC 100 - 240 V
Decoration lamp
Dimmer
Double insulated, Android compatible, iOS compatible, auto power on/off, power off timer, ZigBee Light Link, diffused light effect
Light Bulb
LED
Built-in LED Lamp
Wattage
10 W
Luminous Power
210 lumens
Beam Angle
120 degree(s)
Lifetime
20000 hours
Colour changing LED
Power Requirements
AC 100 - 240 V
Product Material
Synthetics
Body Colour
Clear
Power adapter (UK)
IP20
Warranty
2 years
188 mm
185 mm
20 mm
874 g
