Now expand Hue to your outdoors. The Impress wall light can be connected to your existing Hue bridge to get all the features like away-from-home control and scheduling but is also great at creating ambience.
Special light for special occasions
Holiday cheer starts here - with smart light! Use your Philips Hue lights to transform your home into a festive experience: bright reds and greens for Christmas, subtle pastels for spring or even an eerie purple glow to create the most haunted house on the street at Halloween. -
Unwind with warm to cool white light
Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year. -
Paint your outdoors with 16 million colors
With Philips Hue outdoor lighting, there's no limit to the magic you can add. Play with 16 million colors and all shades of white light to create the effect you want. Highlight objects, trees or pathways to make your space stand out. Use the Hue app to save your favorite light settings and recall them whenever you want with the tap of a finger. -
Set timers for your convenience
Enjoy longer evenings outside, finish gardening or just put the rubbish outside after sunset. Have your Philips Hue lights turn on automatically by setting schedules or use the sunset/sunrise routine. And of course, you can also turn off or dim your lights this way. You'll never have to worry whether you've left any lights on. -
Weather-proof (IP44)
This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use. -
High light output
This Philips Hue light provides you with enough output to light up your garden comfortably. Use this Philips Hue light to help you light up your entrances, create more ambience and bring your outdoors to the next level by setting the scene for your moment. -
Set your lights to welcome you home
Experience the comfort of your lights turning on automatically when you arrive and turning off when you leave. Unload your car, enter your house, all with the comfort of the right light. Either use the Philips Hue outdoor sensor, or set the Hue app to Home or Away mode to switch on all your lights, or let geolocation do it for you, all without touching a button. It's as easy as that.
- Philips Hue Impress - wall lamp - LED light bulb x 2 - 8 W - black
- Product Type
- Wall lamp
- Light Source Type
- 2 x LED light bulb
- Supported Light Bulbs Qty
- 2
- Dimmer
- Black
- Wattage
- 8 W
- Wattage Equivalent
- 49 W
- Energy Efficiency Class
- A
- Luminous Power
- 1200 lumens
- Intelligent Assistant
- Indirect
- Platform
- Hue
- Communications Technology
- Zigbee
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- Wall lamp
- 2
- Supported Light Bulb Wattage
- 8 W
- Compatible Light Bulb Energy Class
- A
- Dimmer
- Double insulated, weatherproof, outdoor usage, 16 million changeable colours
Light Source
- Wattage
- 8 W
- 49 W
- A
- Luminous Power
- 1200 lumens
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Communications Type
- Product-to-product
- Zigbee
- Voice Controlled
- Indirect
- Product Material
- Metal, glass
- Body Colour
- Black
- IP44
- Warranty
- 2 years
- 11.7 cm
- 24 cm
- Length
- 19 cm
- 1.825 kg
- Shipping Dimensions (WxDxH) / Weight
- 16.6 cm x 23.6 cm x 29.5 cm / 2.07 kg
