Brand
Philips Hue Fuzo White Pedestal - Black 1x15W
Quicklinx: GVYFWS00 Mfr#: 915005733202
Type: Outdoor lighting
Compatible With: Alexa
£91.29 ex VAT
£109.54 inc VAT
Expand Hue to your outdoors. The Fuzo post light can be connected to your existing Hue Bridge to enjoy all features like away from home control and scheduling, it truly welcomes you home with high light output. Hue Bridge not included.
  • Weather-proof
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use.
  • High-quality aluminum and superior synthetics
    The products are made specifically for outdoor use. Philips uses the highest-quality materials to ensure the best performance in outdoor conditions, as well as smart use of materials to optimize radio frequency.
  • Requires a Philips Hue bridge
    Connect your Philips Hue lights with the Bridge to control your lights from your smart phone or tablet via the Philips Hue app. Or control your Philips Hue lights with the Philips Hue dimmer indoor switch for on/off and dimming functionalities.
  • Set timers for your convenience
    Enjoy longer evenings outside, finish the gardening or just take the rubbish out after sunset. Have your Philips Hue lights turn on automatically by setting schedules or using the sunset/sunrise routine. And of course, you can also turn off or dim your lights this way. You'll never have to worry whether you've left any lights on.
  • High light output
    This Philips Hue light provides you with enough output to light up your garden comfortably. Use this Philips Hue light to help you light up your entrances, create more ambiences and bring your outdoors to the next level by setting the scene for your moment.
  • Control it your way
    Connect your Philips Hue lights with the Bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add the indoor switches to your system to change your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple Homekit and the Google Assistant to allow you to control your lights with your voice.
  • Smart control, home and away
    Light up your outdoors and see what's going on outside. By connecting your outdoor lights with the Hue Bridge you can control them in any way you like. With the Philips Hue outdoor sensor, the indoor remote control options, such as the Philips Hue app or using your voice (Amazon Alexa, Apple HomeKit or Google Assistant), you can control your outdoor lights. You can set light schedules to mimic your presence. Control your outdoor lighting from the comfort of your home or from any other location.
  • Set your lights to welcome you home
    Experience the comfort of your lights turning on automatically when you arrive and turning off when you leave. Unload your car; enter your house, all with the comfort of the right light. Either use the Philips Hue outdoor sensor, or set the Hue app to Home or Away mode to switch on all your lights, or let geo-location do it for you, all without touching a button. It's as easy as that.
Philips Hue White Fuzo - pedestal light - LED - 9.1 W - warm white light - 2700 K - column - black
Pedestal light - column
Light Source Type
LED
Style
Contemporary
Dimmer
Wattage
9.1 W
Wattage Equivalent
80 W
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
1160 lumens
Intelligent Assistant
Google Assistant, Alexa
Platform
Apple HomeKit
24 V
Frequency Required
50 - 60 Hz
Pedestal light
Style
Contemporary
Shape
Column
Dimmer
Waterproof
Double insulated, weatherproof, outdoor usage, dustproof, app-controlled, lighting schedules, power on/off timer, voice control
Light Source
LED
Built-in LED Lamp
Wattage
9.1 W
Wattage Equivalent
80 W
Warm white light
Colour Temperature
2700 K
Luminous Power
1160 lumens
Lifetime
25000 hours
Power Requirements
24 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit
Product Material
Aluminium, synthetics
Body Colour
Package
Box
IP44
Warranty
2 years
10 cm
10 cm
40 cm
1.61 kg
16.5 cm x 16.5 cm x 46.5 cm / 1.857 kg
Brand: Philips
Stock Status: In stock
