Connect the Philips Hue White ambiance Explore wall light to your Philips Hue system and enjoy natural light that helps you to wake up, energize, concentrate, read and relax.
Installation-free dimming
Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation. -
Get the right lighting angle
The movable head of this wall light is designed to direct the light where you need it more. -
Wake up and go to sleep
Philips Hue will help get you out of bed the way you like it, helping you to start your day feeling refreshed. The light brightness increases gradually, mimicking the e ect of sunrise and helps you to wake up naturally.
- Philips Hue White ambiance Explore - pendant lamp - LED light bulb - E27 - 6 W - daylight to warm white light - 2200-6500 K - white
- Product Type
- Pendant lamp
- Recommended For
- Kitchen
- Light Source Type
- LED light bulb
- Supported Light Bulbs Qty
- 1
- Dimmer
- White
- Socket Type
- E27
- Wattage
- 6 W
- Wattage Equivalent
- 60 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Daylight to warm white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 806 lumens
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Communications Technology
- Zigbee
- Voltage Required
- AC 230 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- Pendant lamp
- Recommended For
- Kitchen
- 1
- Supported Light Bulb Wattage
- 9.5 W
- Compatible Light Bulb Energy Class
- A, B, C, D, E, A++, A+
- Dimmer
- Protection class I, Android compatible, iOS compatible, remote controlled, ZigBee Light Link, glare-free light, 4 lighting programmes, power on/off timer
Light Source
- LED light bulb
- Socket Type
- E27
- Wattage
- 6 W
- 60 W
- F
- 2200-6500 K
- Luminous Power
- 806 lumens
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 230 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Included
- Hub Compatibility
- Philips Hue Bridge
- Supported Host Device Platform
- iOS, Android
- Zigbee
- Voice Controlled
- Indirect
- Product Material
- Metal
- Body Colour
- White
- Included Accessories
- Dimmer switch
- IP20
- Warranty
- 2 years
- 18.1 cm
- 18.1 cm
- Min: 43.6 cm - max: 243 cm
- 1.65 kg
- Shipping Dimensions (WxDxH) / Weight
- 39.3 cm x 24.8 cm x 34.5 cm / 2.68 kg
