Philips Hue Dimmer Switch
Quicklinx: DL69WS00 Mfr#: 929001173761
Type: Dimmer
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
£14.99 ex VAT
£17.98 inc VAT
  • Dim your Philips Hue lights
    Using the Philips Hue dimmer switch, you can smoothly dim your favorite light setting up and down.
  • Place it where it matters
    The Philips Hue dimmer switch works as a normal wall switch and dimmer. You can place it anywhere you want, using screws or the adhesive tape on the back plate of the switch.
  • Use as a remote control
    Pick up the remote and use it wherever you want for your comfort. The control unit of the switch is magnetic and can be removed from the base plate.
  • No wires - battery powered
    The Philips Hue dimmer switch is battery-powered, so there is no installation required.
  • Switch between scenes
    When using your dimmer switch with Philips Hue white ambiance or Philips Hue white and color ambiance products, you can use the on-button to switch between 4 light recipes, or use the Philips Hue app to configure your favorite 4 scenes. It's all up to you.
Philips Hue Dimmer - switch / dimmer
Switch / dimmer
Functions
Light control
Power Source
Internet of Things (IoT) Platform
Hue
Intelligent Assistant
Indirect
Wireless - ZigBee, 802.15.4
Frequency Band
2400 - 2483.5 Mhz
Europe
3.5 cm x 1.1 cm x 9.2 cm
Switch / dimmer
Functions
Light control
Power Source
Wireless - ZigBee
Max Range Indoors
12.7 m
Frequency Band
2400 - 2483.5 Mhz
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Communications Type
Product-to-product
Communications Technology
Zigbee
Voice Controlled
Indirect
Europe
Battery Required
1 x CR2450
Warranty
3.5 cm
1.1 cm
9.2 cm
67 g
-10 °C
45 °C
5 - 95% (non-condensing)
Type: Dimmer
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
