Philips Hue Dimmer Switch
Quicklinx: DL69WS00 Mfr#: 929001173761
Type: Dimmer
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
20 in stock
£14.99 ex VAT
£17.98 inc VAT
  • Installation-free dimming
    Connect the Philips Hue Dimmer switch to your Philips Hue bridge, configure it, and control your favorite Philips Hue light scene without using your smart device. You can turn your lights on/off, or smoothly dim your favorite light scene to the right brightness.
  • Fast and simple installation
    The battery-powered Hue Dimmer switch can be used as a regular wall switch. You can place it anywhere you want, using screws or the adhesive tape on the back plate of the switch. It is a fast, simple installation with no wires and no hassle.
  • Easy wireless control
    The switch is magnetic and can be removed from the back plate. This allows you to also use the Philips Hue Dimmer switch as a remote control for your light with an indoor range of several meters.
Philips Hue Dimmer - switch / dimmer
Switch / dimmer
Functions
Light control
Power Source
Wireless - ZigBee, 802.15.4
Frequency Band
2400 - 2483.5 Mhz
Europe
3.5 cm x 1.1 cm x 9.2 cm
Switch / dimmer
Functions
Light control
Power Source
Wireless - ZigBee
Max Range Indoors
12.7 m
Frequency Band
2400 - 2483.5 Mhz
Europe
Battery Required
1 x CR2450
Warranty
3.5 cm
1.1 cm
9.2 cm
67 g
-5 °C
45 °C
5 - 95% (non-condensing)
Type: Dimmer
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
